  • Replies 65
There is no such thing as a good kit period. Halogen housings have different optics to xenon housings, so they cannot focus the light properly. End of story. The only option is a retrofit of oem hid into the housing.
I'm guessing that you hvae an r34 gtt? with the xenons that have been converted from compliance?
I forgot the blokes name, but there's someone with a black r34 on here who put a kit converted headlights. The light output was crap, because the kit puts the focal point of the bulb in the wrong spot.
Go oem. r34 headlights aren't that expensive. I've seen them go for $600 for the pair in perfect nic.
hmm how do i get OEM?? I contacted my car dearler.. 1 guy said ok.. and another told me they can't do it (bastard).. it'll cost me 800 bucks and that he'll (the guy who said that it can't be done) ask his 'friend' about it..
is 600 bucks about the price for them to make it OEM R34 xenon headlights for me?
heers
i've seen halogen (4 door/non turbo) assemblies go for $600, but watching what people are finding over in the Slidewize R34 gear thread, low $900's is the lowest i've seen him quote how much a pair of xenons will cost from the yahoo auctions (delivered)
If you look at your lights evil, do you see the word 'Xenon' embossed anywhere?
I'm looking at those Xenon HID kits on eBay, sells for around $200-$600.
Thinking of getting 1 but dunno if it'll fit or not, what's the criteria?
And does any1 know the diff between xenon & bi-xenon ones?
110% gtst - have you read a single thing that was said in this thread? If you had, then obviously, you wouldn't buy it.
nah not really, maybe the 8000k bulb will be less blinding, anyway does the Series I & II both have H1s?
MANWHORE, iv got an r32 gtr and i was really keen on a HID xenon kit but from what iv read they seem to be usless what do you recommend for me, my lighting at night is shit house
Same here... I've sold it by hooking up sum CAT foggies!
ali, check out Ronin's thread.
The projector's with HID kits are passable from what i've heard. Obviously not the best option.
how handy are you with building things, electrics, etc? maybe you can do a retro fit yourself.
hey ali,
The link that gohan posted up is spot on the money. It is the only 'Real' and 'proper' way of doing things.
r32 headlights are renouned for being the crappest lights ever. If you don't want to go the retrofit option, the best light you can get is probably a set of plus 50 bulbs, relayed so that they get the full 13.8 volts (instead of the 10-11 volts they usually get).
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
