  • Replies 65
so the xenon's on a series 2 are H4 or the H7? and i suppose instead of the oven a heat gun will suffice?
I'm pretty sure it's H1 as MANWHORE's reply to my Q on page 2 implied, unless he didn't answer it respectively.
there was a third series for GTR's, not sure if it was across the range, probably not.
But there were S3 R33 GTR's, factory standard Xenons, red stitching on the inside, and some other changes that i never remember.
damn.. super cheap auto tells me its the H7 and i bought a pair.. can anyone else confirm for sure?
the thing is, there isn't really another direction that's all :pirate: Without retro fitting projectors. So OEM or projectors. They're the good options.
Look, to be honest, if you're just doing 99% city driving, and you're willing to point your headlighs down a little, you could get away with an a/m HID kit.
They're not the best option, but for just city driving you'll be ok. Seriously, a lot of ppl these days are just driving with the foggies on and when you think about the amount of street lighting, and lights from other cars, you can get away with it.
Some people don't really care for the finer details of this all, fair enough, that's cool. Despite being glary, it's hard to argue that they don't look pretty shmick. And as with most modifications to our cars, there is some law, somewhere, saying not to do it.
If you're not fussed, go for it. As OEM for R34 is easily $850+, more the $900's. I've been looking at the yahoo auctions quite closely, and you just don't seem to be able to land anything for less than $850.
You can do the retro fit if you're handy with those sorts of things. But you'll still have to buy some projectors, and then buy a HID kit, with the D2r types globes, etc. Still looking at roughly $500 for those parts, and you still have to put it together.
So yeah, choice is yours really. This issue comes up more with R34 Xenon owners, as our healight assemblies were designed for another bulb. Now, i'm not saying R33 and R32 lighting is brilliant, but at least everything is as it should be.
cheers,
daniel
Unless yours have been converted that's most likely incorrect.
Series 1 R32: H3 (high) and H3C (low)
Series 2 R32: H3 (high) and H1 (low)
there's series 2 r32? sure u meant r33 for the stuff u just said?
Yeah I meant R32. Series 1 R32s were made from May 89 - August 91, and Series 2 from August 91 - August 93. One way to check is the colour of your dash, series 1 R32s have a blue dash, series 2 have a black dash (applies to GTST, not sure about GTR).
Bulbs did not change in the R33 range (except in the series 3 GTRs which had xenons as previously indicated).
hey there mate.. which are projector style xenons? which car maker uses them? honda and lexus? those 2 are cars that i've seen headlights that I thought was difference from the R34s..
cheers
from factory?
BMW
Audi
Mercedes
Nissan (new 350z)
Honda
Lexus
Lambo
Ferrari
Porsche
Holden (on the top of the line, new models, only took about 500 years for them to catch up)
Aston Martin..
Mazda RX8
etc, etc... you get the idea. It's more a luxury item at this stage.
Volvo have reflector Xenons, like the R34's. And i think Lexus's first Xenons were done in reflector assemblies as well. Now-a-days, very FEW manufactures make Xenons which DON'T use projectors.
Lots of manufacturers use and have used for a while, projectors, it's just that some cars get Xenon globes in the projectors as oppose to normal halogens. A lot of cars on the road have projectors, but aren't Xenon.
But if you want to do a retro-fit, you don't have to buy spare parts from a car manufacture. Hella/Bosch, etc, make projectors. And i would imagine most car companies would use projectors made by those big companies.
the HIDplanet forums are really the BEST place to check up on all this.
hey ali,
The link that gohan posted up is spot on the money. It is the only 'Real' and 'proper' way of doing things.
r32 headlights are renouned for being the crappest lights ever. If you don't want to go the retrofit option, the best light you can get is probably a set of plus 50 bulbs, relayed so that they get the full 13.8 volts (instead of the 10-11 volts they usually get).
Hi um ive been going mad looking for the thread to relay the headlights, does anyone know where its at? I'm sure ive seen it once before but just cant find it.
Thanks
  • 3 months later...
i was try to do retro on my R34... but i dont think i cant do it...
might i screw all up... i try to find OEM xenon... but i cant find them..
anyone know where i can find? i must import from japan right?
if anyone did it.. can i please have the pictures?
cheers
paul
I had 8000k HIDS my car,they were in for 2 weeks then got defected,pulled them out and sold them on ebay.To much glare in reflector style headlights like R33s.Only suited to projector ones IMO.
no-one really answered this but you can get oem zenon headlight for r33 series 2's. they were only avaliable in the late series 2 models, i had some on the shell i just bought but they were f*ked so i cant use them, got a quote on brand new ones and they are $1300ish each light, and good luck finiding them second hand probably anyone whos got em dun know, and if they doo i wouldnt ever be selling them
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
