Hey all I'm considering getting a Power FC and a set of Adjustable cam gears for my R32 GTR and was wondering what kind of power gain will I get from that. The car currently is making 240 rwkw on 14psi. It has N1 turbo's and cams. Also approx how much would I be paying for the power FC and hand controller.
So the ecu is remapped?
Must be. Sorry havn't really had a chance to have a good play around with the car since I've had it and it's sad cause I've had it for 4 yrs now and done all of 9000km it, So I'm only really going on what the guy I bought it off of told me.
Yer either way.. The PFC is the next step if you want to try keep up with Andrew. :)
I can't wait to get home and check that thing out. I think i'll go ahead and get a Power FC I'd love to get it up around the 300 mark that would keep me happy for a while.
As soon as you see 300rwk's budjet for a new clutch. LOL
power fc is definetly worth it . Go for the jetro if you can. Mine went from 199rwk's to 185rwks with mods, and power fc added and tuned 260rwk's. I make 292rwk's now with 1.1bar with N1 turbos. You should see aleast that power level because I still have standard injectors. good luck.
Sorry not knowing much about these what is the jetro and what are the difference's????
main diff with the D Jetro to std PFC is it uses MAP sensors and removes your AFM
just incase you dont know... MAP = Manifold Absolute Pressure and AFM = Air Flow Meter
RellikZephyr
Edited by RellikZephyr
292rwkw's on standard gtr injectors? do you have a fuel pressure regulator? what dyno was this on?
Edited by mr_rbman
Ash,
They 'should' do it with around 43-45psi base pressure and close to 100% duty. 43.5psi they flow 520cc's & 40psi 480cc's. Well mine did so yours will be no different.
I'm unsure if the GTR's as standard run a slightly higher base fuel pressure.
Did 292rwk's on peter halls dyno. Have seen them do 299rwk's on tilbrooks dyno but was running a bit lean .
As cubes said though , getting very close to full duty. As far as the pressure , unsure.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
