So here the story goes.
Got a set of coilovers today, got to work installing them. Front drivers side came out like a dream, took about 15 mins to replace.
Moved over to the front passenger side, loosened all the nuts, thinking it was going to be a repeat occurance and fall right out like the last one but boy was i mistaken. This little bitch will not budge.
I've tried jumping up and down on the wheel, somewhat levering it with a breaker bar but no hope. Is there some sort of trick to this? The front drivers side was taken out and replaced about a year ago, so I'm guessing this is why it was loose compared to the passengers side.
Any help would be greatly appreciated :laugh:
Thanks in advance,
Mark
:rant:
https://www.sau.com.au/forums/topic/161694-r33-strut-removal/
are both the front wheels off the ground? you cannot do one side at a time as umm... one of the components (steering rack? cant remember) applies pressure onto the hub.
found out the hard way when i was doing my gear... was too lazy to put axle stands so i had two trolley jacks either side.
the sway bar applys pressure from one side to the other..
you may need to use a long lever in the form of a pole, or so on... And a jack under the lower control arm to take the weight off it.
Not reall hard to do, but if you do a few things to assist it it will pop right off.
yeah, ended up jacking her up and throwing it on stands, undid the swaybar supports and jumped on the wheel for a while which got it out, then used a jack to lift the arm back up so i could position the strut and bolt it in... easy eh oh well, thanks for all the help guys, much appreciated :P
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
