  • Replies 156
If someone got my 12.4 on video I'll lick your toes.
Start preparing to suck....lol
Got it on teh video.... il burn a copy tomorrow for you... Just let me know if you want me to bring it to the monthly dinner or if you want it posted :D
So anyone heading to WSID next wednesday. Thinking of going and claiming that 11 finally will depend on how the practice goes at EC this friday though and how much the car has to be adjusted for the SS round 2
If its all good I am there with a few big blue bottles
Can you please give it to Amy at the dinner please? Cheapest way but I can't make it to dinner.
Amy will lick your toes for me. :glare:
Depends how quick I can get this GTR rear end in.
No worries... will do Adam :D
And its Steves toes she can lick... mine are tooooo ticklish :glare:
Jason... me and the sunny are planning to head down next wednesday...... possibly a couple of others from Hornsby too
Awesome!
I've got my 4wd working !!!
fantastic Mr charlie I have some great footage of your car will attempt to burn you a copy when I get my new computer
NOS ..... I mean Nice lol
Wont be able to make it next wednesday but i think ill go down the wednesday after and test out my new tyres and clutch, assuming the car is still running after the drift day
Dude checked the other video tape last night and got you doing a masive burnout and sounded awsome
Oh i am waiting for my transmitter for my in car camera to come back from the fixit shop fryed the internals ..bla bla anyway when I get it Ill need some cars to chuck it in so ill be looking forward to the next event people
Edited by nuttsHunglow
Cooool! I know they don't like actual video cameras in the car.... guessing this is the really small ones like in the V8's n stuff???
The things i do for you....lucky feet dont phase me ;)
You won't be saying that after you see Steves's feet :P:ninja:
You won't be saying that after you see Steves's feet :P;)
Yeh it is so small but the picture is so good it is on par with my digital video with a rang of almost 1km
can record straight to lap top
i had a camera in my car once... but i was swearing at the guy about him delaying me, i forgot the camera was running.. oops!! hes never spoken to me again! lol!!
Oh ill volunteer, it would be great to have a camera in my car filming.
Me too please... id like some vids of my runs if anyone has any... and happy to pay costs.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
