  • Replies 141
if his car is hard tuned....does that make mine a soft cock? Surely im right if things are all back to front these days.
Hey shane...dont go with your biased few on hard tuned gtr's and gtst's....i reckon they do compare and i think ours is proof of that...when its got its eye of the tiger going :P haha.
urs is a stripped out track car biatch, can we compare urs against, say giants? :huh:
P.S can i "borrow" ur dry sump setup? :happy:
if you want...on the national giants only a sec quicker and 2 on sprint...but next time we hit the track...we should be just as quick if not quicker....but i admit giants car is a very well setup beast.
No...the dry sump is MINE! Get your own. I can show you how to fit it up good and proper.
You will love the new 26/30's soon to be built...sporting t04z and a few other bits.
And the new gearset going into the box oh and autronic.
Edited by r33_racer
Series II,
You belong on boostcruising.com :)
Your replie's hurt my brain everytime i read them, and u ramble on about rubbish in ur posts.
Also, a 'hard tuned' gtst just doesnt compare to a 'hard tuned' gtr :laugh:
My GTST would eat most hard tuned GTR's. I'm running low 7's now.....on street tyres.
If you tastefully modify a GTSt for a track purpose instead of chasing XXXrwkw, you should be fine and have a ball. Hell, Jason has been doing it for years and has been quicker than most...
Here here. Skylines are pretty tough things, if you keep them very well maintained spend some dollars on suspension, brakes and cooling rather than chasing those big rwkw that you can't use on the street anyway, you can have fun thrashing around the track, down the quarter and at the skidpan without fear. I have only had a skyline fail me once and that was after picking it up from getting a full respray, for some reason the AFM decided to pack it in. . . . nothing really. I have done numerous trackdays at QR and Darlington Park, plenty of runs at willowbank and a few days on the skidpan and LVMA at Mt Cotton and soon Gympie, and have never had a problem.
Don't get me wrong I would love some big hp, then I could have some real fun I am sure, but then I am sure I would spend a lot more time off the road too as more hp means more stress on the engine and drivetrain and an inevitable failure. If you love driving you skyline then will be addicted after only one lap! Its great fun :happy: I highly recommend giving it a go.
And correction. . . . I am slow. . . .
I'm saving up for a parachute b4 I even attempt to hit the drag strip
It costs too much for me to go to Willowbank anyway....coz my traction level is so high it actually reverse rotates the earth on it's axis which turns back time. This is how I am able to run such quick times. The only downfall is that due to my high levels of traction, I tear up the bitumen and this has to replaced at my expense. If only I could find another way...hmmm.
Hey Andy, how did the new clutch go on that last 2 you pulled...she still running sweet. You know it's an NPC rebuild so Shane might get jealous that it didn't explode, causing your car to be written off in the process.
lol thats gold.
Are you guys being serious or taking the piss? In this thread its hard tell...josh and andy?
Edited by r33_racer
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
