  • Replies 518
Posted Images
I received the boots today and for those who have paid I have express posted your boots to you and you should receive them tomorrow Thursday (2nd) if you are in the AusPost express area code. Otherwise you should receive them on friday. PLEASE LEAVE TRADER FEEDBACK ONCE YOU HAVE RECEIVED YOUR BOOTS AND I WILL DO THE SAME FOR YOU
added you to the next group buy Tyline
NEED TWO MORE MEMBERS FOR THE NEXT GROUP BUY TO GO AHEAD
These boots are made for walkin. Put me down for a set, Bro. R33 Please.
Edited by BigDatto
Thanks Pablo,
recently recieved my set and they look good, highly recommend them, dont be shy people step up, this stuff is good.
Thanks again Pabs
AUGUST 7th UPDATE:
We now have enough members for the group buy to go ahead! If you are late to join this group buy send me a PM or post here and I will include you for the next one (it fills up quickly so it wont be a very long wait)
PM with bank details have been sent to all those on the list.
AS SOON AS EVERYONE PAYS THEN I WILL ORDER THE RIGHT AMOUNT OF BOOTS. It's really a group effort that everyone pays as quickly as possible so everyone gets their boots quicker!
And so I can order the right amount and forward your payments so that I am not left with unclaimed boots. For those who pay I will indicate this above next to your name.
Payment deadline is Wednesday 15th August.
Edited by pablo101
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
