Hey I'm really hoping there is a simple solution to this problem but then again i'm prepared for the worst.
Basically my car now runs sh#thouse on boost. Driving around town feels normal and fine but as soon as you give it a little say over 50% throttle, it holds back, and feels like its labouring - like being in to high of a gear, then kicks in and drops out again. It only started doind this in the last day or so, and previously it had been running real well on 11psi since the new pump and safcII tune. But now it feels like its going into R&R type of mode or something real early in the rev range - from about 2000rpm. something is definately wrong, boost still ramps up to 11psi but the car feels DEAD - as in overtaking would prove an issue...
Any ideas??? Anyone encountered this problem before and fixed it???
Mods are listed in signature, plugs were re-gapped to .8 when i had the cooler done. It was fine before, so some existing part has stuffed up i would think.
Any help would be much appreciated - I'm sick to death of this thing being so temperamental.
Edited by R33silverS2
https://www.sau.com.au/forums/topic/162044-car-runs-like-like-crp/
Yeh all possibilities i guess that i will have to look into. Thanks to those who replied.
Thing is i just came back home now and it was driving like normal again... :P but it did it yesterday as well for a bit, so it seems very temperomental. When it was doing it earlier this afternoon it was quite warm, i popped the bonnet to check all the vac lines etc for leaks (none found) but i touched the front of the pod and it was damn hot. The pod itself is stainless steel so i guess it heats up quite a bit (un-shielded) - bad i know... shame shame. Could it be as simple as this?? As in requiring a heat shield for the pod and a clean of the afm possibly?? I noticed that some people are not very convinced on the stainless pod's filtering potential (blitz). I havent noticed it doing it when the whether is cold, but thats purely cos the problem has only seem to have arisen in the last couple of days, and haven really been testing it in different conditions. Would sucking in really hot air be the problem maybe?? perhaps amongst other things like plugs etc...
just a suggestion - make sure you have the right spark plugs , as far as hot and cold tollerance . many problems can arrise if they arent the right type . clean your AFM out with carby cleaner - look into some modification around your pod - to prevent excess engine heat entering . im currently in the process of trying to get my pod lowered down into my front bar if possible. saving me making an enclosure , and hiding the pod from cops.
Could be a lose connection to a sensor, was it doing it before you had the pod filter on there?
Pods been on there since i got the car, so it had been running fine for the most part previously. Just seems odd cos its not like i have changes something ecently casuing this to happen. It just happened by it self sorta thing. Perhaps certain components are starting to fail or need cleaning etc.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
