Hey i seem to have a problem with battery performance in my R33 GTST.
The battery has an indicator on it that is green when fully charged and changes to black when it needs charging and i was told by the guys i brought it from that it should always be green aven is i dont start the car for a couple of weeks, but from green it only takes a few days for it to drop down a little and turn black. I have an alarm in the car and that is even when the alarm isnt turned on also, acording to the alarm specs the current draw with alarm off is 9mA and when on it is 20mA.
what else could be draining the battery when the car is off ??
Does anyone else have this problem ?
I dont drive it much and it only gets started every couple of days.
Please help me.
https://www.sau.com.au/forums/topic/162341-battery-problems/
no if the car wasnt started in 2 weeks it would be dead
Also i forgot to mension the battery was brand new, and when i took it back because i thought the battery was faulty they replaced it for me and its still doin it so i know its not the battery.
Whole bunch of stuff that draws on the battery when everything is off, like the radio needs battery to maintain all the pre-set stations and its clock.
The other common one is the boot light not turning off when the boot shuts.
Do you have a multi-meter?
Yer i know its not the boot light cos i have the rear speakers out and i can see in the boot through the holes.
Yer i have a multimeter, and im very good with it, i used work in electronics, wiring, soldering etc ..
So what or how should i test what exactly, what are you thinking ?
I just carnt think of how i can test what is drawing power, is there a way to test the load draw on tha battery with it ?
Remove +ve battery terminal and measure amps (everything off) between battery post and terminal clamp. If you confirm a serious current draw, then you need to go through each fuse and work out which circuit(s) are drawing current.
Hey thanks for the help, i realy appreciate it.
So you want me to remove the positive battery terminal and measure amps from where exactly?
The negative terminal of the battery and the bare positive battery post (with the terminal removed)
Is this right ?
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
