SHOWOFF Car Show Dyno Results - BMT Cleans UP!!!
Hey guys, just thought I'd like to share some good news with you all. BMT made it's debut show appearance with a few cars. Thanks to the organisers of SHOWOFF for a well run event.
MR KILOWATT OVERALL RESULTS
1st Place Overall - BMT Prepped R33 GTST 396 RWKW 1180 NM
2nd Place Overall - BMT Prepped R34 GTR 300 RWKW 1080 NM
3rd Place Overall - BMT Prepped R33 GTR 288 RWKW ??? ft/lb
6 Cylinder Class
1st Place 6 Cyl - BMT Prepped R33 GTST 396 RWKW 1180 NM
2nd Place 6 Cyl - BMT Prepped R34 GTR 300 RWKW 1080 NM
3rd Place 6 Cyl - BMT Prepped R33 GTR 288 RWKW ??? ft/lb
AWD Class
1st Place AWD - BMT Prepped R34 GTR 300 RWKW 1080 NM
2nd Place AWD - BMT Prepped R33 GTR 288 RWKW ??? ft/lb
3rd Place AWD - G-Tech Prepped '03 WRX STI with NOS 255 RWKW ??? ft/lb
4 Cyl Class
1st Place 4 Cyl - BMT Prepped S15 200SX 216 RWKW ??? NM
2nd Place AWD - G-Tech Prepped MR2 176 RWKW ??? ft/lb
3rd Place AWD - ???
Sorry to all you V8 lovers out there but I wasn't paying attention to them, but I know G-Tech did well and got 1st and 2nd with a pair of commodores around 250 RWKW mark.
It was a pretty cool show with some nice cars, thanks heaps to everyone who helped us get the workshop of the ground and get some of our cars to the show.
Doc.
Currently the workshop is at 34 Lambert St in Richmond, it's just temporary till our big workshop is fully operational in 2-3 weeks....
Dyno pit getting dug next week....
mmmmmmm dyno......
That's right fella's.... Daves 33 did make the 396, and he also has the R32 Drag car with a lot more than the 33. The 32 is currently undergoing a RB20 transplant to finalise compliance and rego, and the RB26 will be rebuilt and tweaked some more... watch out Auto salon....
mwahahahaha....
Doc.
Guest INASNT
Originally posted by Dr_Drift
Yes dave likes monsters :)
Wait for the 32... expecting 500+ rwkw !!!!!!!
the australasion record is 536rwkw by a drag GTR from NZ, lets hope he can beat that!
Is the engine a direct drag engine from japan?
also the hks gtr has 1040hp@ 4 wheels or 764kw@4 wheels.
The 33 is driven every day to and from work and behaves superbly, with very smooth throttle response...... That is of course on low boost with and the silencer in...
The 32... well that's another story....
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
