make a program that imitates the FnF laptop "DANJER TO TEH MANAFOLD!!!!" then you can impress your friend by telling it to "shut up"
or you can just give it to me and I use it later to link it to a Emanage or something
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
