He fixed the reverse and is all good 3 years on....but the 4 gear syncro problem reappeared after close to 2 years had passed....and i do NOT flat shift :)
thinking about another rebuild now....:)
Yeah, I'm getting the impression that 4th synchro is piss-weak in this 'box. Seems to be a common complaint. It's making Me think I should've looked harder at a gearbox conversion, but then I really don't want My car off the road for a month while I sort something out - Life sans-wheels SUCKS !
Yeah, thanks abcent - A mate in the trade is seeing in the morning if he can get a changeover from Japanese Gearbox Wholesalers in Rowville, if not I'll probably flip a coin between 360 and Competition - they both sound pretty good, and charge similar rates, and they're practically a stone's throw from each other !
You got an address to this gearbox changeover business in rowville?
Are they open to the public or only to mechanics
Thanks
edit: found
http://www.japanesegearbox.com.au/intro.html
This is like around corner from me! must check it out, thanks for mentioning it :thumbsup:
Thanks
edit: found
NOOO changeover boxes for R33 GTS-T there, and apparently they're not too fond of doing parts - i.e. whole 'box or bust.
Crosses off rb25 gearbox conversion off list.
If they can do a changeover for my rb20 gearbox for cheap i might go ahead with it! ^^,
I've dealt with Stuart (owner) at JGW before, nice guy and he helped me out when dealing with nissan over gearbox issues, but never actually got anything from him so can't comment on what his stuff is like... he seemed to know his stuff, but i think snowy had troubles with his gearbox there...
Well, the bad news is in . . . . .
Nissan have superseded the parts I need (or something), the upshot being that I'd need to buy complete cluster sub-assemblies, which would put the total rebuild bill over $4000.
I shit You not.
P.s. Competition Gearboxes have been great, & both they & 360 Gearboxes can still do a bearings & Synchros rebuild at SURPRISINGLY good prices. I'd suggest anyone with 4th gear selection problems think about a preventative rebuild.
Justjap advertises rb25 boxes for $3200 so i assume you could get them even cheaper shopping around direct from Nissan.
http://justjap.com/parts_ngearbox.htm
Just in the process of cleaning-up the 2nd hand 'box, to install this week/end.
Pics of the old, dismantled box:
5th/Reverse Lockout open:
5th/Reverse Lockout ENGAGED:
H-Pattern the sits below the gearstick . . . . who wants to do a big one inside the cabin - Ferrari Style? ! !
Busted Selector Fork (Notice the worn-smooth bit, where it's jumped-up onto the selsctor Ring when it jammed):
It's even got the rib broken-out:
Hmmmm, What's missing here:
1st/2nd Fork on the left - notice how it's NOT BROKEN ! !
More Brokenness:
I keep on finding bits & Chunks of Aluminium throughout the 'box, not cool. Apparently that's ok though, coz the gear teeth are so hard it just squashes 'em and spits 'em out into the oil ! (hence the T-1000 oil)
WOO HOOOO ! ! ! !
I Went with a cheap 2nd Hand gearbox, which is in, and it feels FINE ! :) Fingers crossed !
Looks like I've got an R33 GTR gearset, and a GTS-T casing + output shaft + spares galore for sale. Make Me an offer !
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
