This is Abusd's bonnet which i couldn't get him to sell me his bonnet.. :laugh:
Fell in love with the bonnet after first time seeing it..
From what he tells me, he got the vents moulded on to his original bonnet but I couldn't get him to tell me where he got the job done or who done it for him?
So folks... know any place or a person who this kind of a job? Moulding vents on bonnets? Where can i go?
This is what i want on my bonnet exactly!!
https://www.sau.com.au/forums/topic/162949-r33-bonnet-bulge/
i think that car has the blinker in the parker lights.
basically you could get a fabricator to make that out of steel, then weld onto the std bonnet.
Or get a BA falcon fibreglass bulge (like on fatz s13) then cut up and insert the vent partitions onto that then glass that onto your cut std bonnet..
The bulge is more then likely an BA falcon bonnet bulge, theres someone on ebay selling just the bulged part which you mould onto your bonnet, a mate of mine bough one for a mustang, the vents will probably have to be your handy work.
Not to be a pain ass mate but is it possible if you could digg up that item from ebay?
Frankly I wouldn't know which part of ebay to look at for this item, there's too many auto parts ranging from sections to section in that site.
Cheers mate
u sure there 400r sides? look vertex style (although they dont make anything for 33's), im after a more subtly kit for mine, the BN sides are friggin huge, look good....but i wanna change it around a little
Edited by Nathan_G1
I think on a series 2 front end the bulge without those vents would look good, as the bonnet on a series II has the lines in it just like a BA. It doesnt suit the series 1 at all I think.
Putting one of them on would put you in the same groups as someone putting a WRX scoop on a skyline..
  • 4 weeks later...
Sorry been away for awhile!!
Indicators are on the extremes of the front bar, on the inside of the side ducts, and the whole bodykit/bonnet/front guards are for sale, if anyones keen!!
Pax, if u still want the bonnet its yours!!
Cars forsale too if anyones interested!!
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
