  • 1 month later...
Originally posted by Sydneykid
Sorry Dennis, that wasn't me, it was Zahos.  We use NGK BCPR7ES-11 gapped at 0.9 mm in the race GTST.  When it starts missing I spend $18 and buy a new set.  The road car gets PFR5A-11's gapped at 1 mm.   I've not had any problems with this combo and they are cheap enough, so never bothered trying anything else.
Hope that helps.
What do you know the same plug and gap as me!
BCPR7ES-11's gapped to 0.9mm.
I still haven't fully tuned the plug side yet.
The Rule of thumb for NGK plugs I use and many others.
PART 1.
5's for 5,000rpm
6's for 6,000rpm
7's for 7,000rpm
8's for 8,000rpm
9's for 9,000rpm
(Where the rpm is the peak horsepower range of the engine or the peak rpms most commonly used).
PART 2.
Aim for a generous gap when aiming for good peak power.
6's may work at 8,000rpm (If this is where your peak power ought to be) if you close the gap enough. They certainly won't work as well as 8's with a decent gap. The trade off being that 8's won't tollerate around town driving as well unless you give it 8,000rpm around every corner.
It's a basic rule of thumb and not perfect.
For those interested on my opinion of the platinum and iridium plugs; both are better than copper. Only in reliable spark and not in power production (not enough to notice). Get the plug setup wrong and you have to turf them anyway... better a cheap ass copper set than expensive iridiums.
my 2c
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
