Heya guys, I'm new around here but have been on PGA for a few years and recently as the Tech section moderator. I am in the process of getting an R34 and going into the Skyline world.
I saw this section and thought I would chuck up some pics of what I do on my weekends for extra cash!
I turbocharged my N/A N16 from scratch ( I did everything except tune it):
Manifold:
Dump pipe:
Exhaust:
Catch can:
Completed engine bay with 3" air intake, custom BOV etc:
Here's a GT Starlet I recently did (Pipework, not the bodykit! :) )
I have done many other cars and miscellaneous bits'n'pieces, but these are a few I have pics of.
Hope you enjoy and I look forward to chatting some.
https://www.sau.com.au/forums/topic/163140-some-of-my-fabrication-work/
  • 2 months later...
  • 1 month later...
Sorry guys I haven't been on of late, been rather busy!
I am busy up until Jamboree, I could look at doing something for you guys after that. PM me and we can tee up some times to see what needs doing.
Rob.
  • 5 weeks later...
awesome work man
very impressed
btw jsut out of curiosity
was all the piping purge welded?
Nah mate, I haven't got all the right pipe bungs at the moment, but the inside bead is still tidy and not much bubbling. I use quite low current to help avoid that, but keeping the weld deep enough to be strong.
Do you have a spare length of air line and a Y piece?
If you do, connect the Y piece to the regulator, and run your air line to the welder as normal. Then connect your spare air line to the other branch of the Y piece. Hopefully you'll have a couple of used cut-off/grinding wheels lying round, drill the center out of one so the end of your spare air line fits snugly inside and then seal it with some electrical tape. You can then use masking tape (doesn't leave so much sticky mess) to fix the wheel to one end of the pipe your purging, making sure you get a reasonable seal. Then do the same with another spare wheel at the other end of the pipe, using the masking tape to seal up the hole in the wheel also, but poke a couple of hole through the tape with the end of your welding wire, this means you get a little bit off flow in the gas which dissapates any oxygen, and evacuates the heated gas.
The only downside with using a Y piece is you might loose a bit of flow/pressure to the welder, so just ramp up the flow on the regulator a little. The best way of course, is to use a twin regulator (which you might already be doing).
And if you knew all that already, my bad and no offence intended, but someone else might not know...
lol! I did actually know all that, but its useful information of course to anyone who doesn't know what purge welding is.
No offense taken at all! :thumbsup:
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
