Item: R33 Rb25 Turbo
Conditon: 2nd Hand - excellent condition. Minimal shaft play
Price: $340 without actuator
Reason for sale: Turbo upgrade, turbo has only just been taken off
Pickup Only unless someone interstate is really desperate.
Other Info: I most likely will need the actuator, hence will be selling minus the actuator. If I can find an Rb20 actuator in the meantime then I will sell it with the actuator. This turbo has the metal compressor wheel not the nylon one which is a bonus.
Great condition, minimal shaft Play. Run at stock boost still last year where it was raised to 9.5psi and made 172rwkw on a conservative dyno. Hasn't seen a track day and I don't drive it hard.
Should be ready for sale by next weekend (just want to check the new turbo works etc before I sell this)
Edited by benl1981
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/
Hi Highcrawler. Nylon is a type of plastic, and it would burn if the exhaust wheel was made of nylon.
Ben's turbo there has a ceramic exhaust wheel, and a steel front wheel - that's what he's saying isn't nylon
Edited by MANWHORE
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3035420
well sorry to correct you mate, but all R34 turbos have a nylon exhaust wheel, as do late model R33s, which this is obviously off. Do your homework before correcting people.
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3035831
100% correct SS Eater - the nylon exhaust wheels are fine for up to 12psi, but any sort of track work over about 10psi will see them shoot down the cat converter.
Awesome for response though, as like you said they have less inertia to spin, which makes for nice early spool up and boost!
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3035996
Nope, I have an aftermarket boost gauge in my R34, and with the stock turbo it showed 7/8psi then up to 10psi (when the 2nd solenoid kicked in at around 5,000rpm).
But once you add exhaust, dump pipe, intake etc, mine went to 10psi/12psi. So yes, you shouldn't be doing hard track days at all if you have the stock turbo, no manual boost control and an exhaust.
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3036025
not to detract from this sellers thread, theres no way the exhaust wheel is nylon, theyre all ceramic from factory, only thing that changed is the compressor wheel, be it nylon or steel.
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3036090
lol .... Google is your friend - there is tons of info about it on the net - plus I have one right here and it is definitely nylon .... it is tuff stuff - but only to 12psi.
All you keyboard warriors need to talk about what you actually know - not what you think you know :)
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3036115
You're spot on the money Dead32, RB25DET standard turbo's all have Ceramic exhaust wheels, pre 1995 they had a steel compressor wheel mated to it. But to make it more responsive, from 1995 onward they put a nylon compressor wheel onto the ceramic exhaust wheel.
Nightcrawler, might need to get back on google and do some research into the melting properties of nylon.
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3036120
ah ok, but the R34 stock turbo I have right here (on my lap) goes a metallic 'ting ting' when I tap the compressor wheel with a spanner, and gives a dull plastic-style 'thud thud' when I tap the exhaust wheel with a spanner. No way it is ceramic - it would make a completely different noise.
And how can by compressor wheel be steel - I was told ALL R34s had nylon wheels. Now I am very confused.
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3036480
like i said no way its nylon exhaust wheel, listen to the 3-4 othe people that have told you your wroung, use google, ive fitted these turbo's and other standard nissan turbo's all been ceramic. now cut the bs and let the seller sell the turbo
https://www.sau.com.au/forums/topic/163270-r33-rb25-turbo/#findComment-3036743
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
