would a welded diff lock up under fast deceleration like the 2ways do??
also those people who have welded theyre skyline diff how long has yours lasted before leaving you stranded???
ill be doing this soon with a 320 odd rwkw r33, my current diff is too unreliable, breaking traction sometime/ sometimes not etc the usual probs.
Edited by humz
https://www.sau.com.au/forums/topic/163618-lockedwelded-diff-question/
lockers can be 1-way, which means they only lock under acceleration. a welded diff is always locked, of course.
I wouldn't do it to a car if I cared about the handling, you'll find yourself driving around the diff. but then, with 320rwkw you're probably having most of your fun in a straight line anyway :thumbsup:
i had a shithouse aussie borg warner diff that comes factory with r31 skyline
filled it with weld
worked for 3 years and was still working when i sold the car
2 of those years with a 240rwkw rb30det driving it
welded diff can be good provided the welding is done well
drift, yes.. it's reversing it across 4 lanes and into a telegraph pole I'm worried about.
you have to be a very sensible driver when you've got a locker. of course, many would debate my sanity in having ZE-326's fitted on a locked axle anyway..
  • 1 year later...
sorry to bring up an old topic.....well not really i need the info.
scenario is im sick of single spinning and losing power out of corners soooo... 2 questions
1. how much, and where in qld/sunny coast can i get my diff welded...can anyone do it?
2. is it possible to transplant a r31 diff into a s1.5 r33. why? the r31 diffs can be minispooled :down:
Edited by r33cruiser
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
