Guest Joeyz
Hi all, hope someone might be able to shed some light on this strange situation.
My engin light has been flickering on and of latley and only have noticed it when i am in 4th or 5th gear. Just cruising around and if i were to put my foot down to speed up it flickers.
Under hard acceleration through 1st to 5th gear it does not come on.
Has anbody had the same thing happen or can i get a few tip's on what to do?
Thanks in advanced.
https://www.sau.com.au/forums/topic/163821-r34-gtt-engin-light/
the check engine light will come on to indicate knocking/pinging...its not good. The factory warning is set to come on at 60, which is pretty high...tuners like to keep it under 20 when tuning aftermarket ECU's
If its only happening in 4th or fifth gear, I'd say you're in the wrong gear to be accelerating that hard at the time, and putting too much load on the engine. if you were to drop back to 3rd and accelerate that hard, chances are you wouldn't get the knocking as it sounds like your car is fine the rest of the time....
Have you got an after market ECU and a tune? or still on the stock ECU?
Either way, its not good, so I wouldn't keep doing what you're doing...take it somewhere and get it checked out :stupid:
Guest Joeyz
I'v only had the car about 6 weeks and know that it has a APEXi Power FC.
You said that the car might be knocking, I can't hear any noises like that. I used to be a mechanic about 4 years ago and i'v heard what that should sound like and i can't?
I never worked on car's like this before or up untill i bought it.
I do have planed to take it to a dyno and get it tunned fairly soon though.
you don't have the pfc hand controller do you? umm I seriously think there's a flaw in 34s pfc....I've heard ppls pfc sorta "detune itself" every few months, initially knocking at 5th then move down to 4th ..etc..
agree - definately knock
note ur load speed revs and gear to help the tuner out
i'd also consider in investing in the handcontroller (while they're still available)
feedback info on display very usefull (such as knock and water temp)
goodluck with it
Guest Joeyz
Nah don't have one. Looks as though the previous owner didn't have one or sell it with the car. When you say hand controller is it conected to the PFC or not? Never seen one.
I suppose E-Bay or buy one brand new for the car?
I noticed this problem myself, except my engine light flashes very rapidly at the end of 1st and sometimes 2nd. Only saw it happen once or twice though, apparently the owner who I bought it off said his car would knock alot too. Is this a common R34 problem or could it be something on my end? As in the unit itself or the actual knock sensor?
Guest Joeyz
Hi all!
Thanks to all that replied about the engin light.
I was able to get my car dyno tuned today by Castle Hill Exhaust and he brought back the timming a bit so the light would not come on. All is good now! Yeah!
My car started at 178kw and the final outcome of the tune was 199.9kw at the rear wheels. Very Pleased.
Thanks again :P
Hi all!
Thanks again :P
What sort of work has been done to the car to acheive those figures?
Hey mate...I wouldn't be running 15psi through the stock turbo...unless you want it to fail and have to replace it.....generally the safe limit for them is about 12psi...you might find you'll make more power on lower boost too....I make 200-205rwkw with the same mods on an R33 at 12psi...
Guest Joeyz
It has a front mount intercooler, 3inch exhaust all the way through, Apexi power FC computer, K & N Air filter, HKS Blow off valve.
When dyno'd on saturday, it was running at 1 bar and now it has been adjusted to 15psi.
Guest Joeyz
I don't understand how i will make around the same power running less boost :thumbsup: can you tell me how that is?
I still am learning a lot about the car, only had it 6weeks.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
