Guest Joeyz
Hi all, hope someone might be able to shed some light on this strange situation.
My engin light has been flickering on and of latley and only have noticed it when i am in 4th or 5th gear. Just cruising around and if i were to put my foot down to speed up it flickers.
Under hard acceleration through 1st to 5th gear it does not come on.
Has anbody had the same thing happen or can i get a few tip's on what to do?
Thanks in advanced.
https://www.sau.com.au/forums/topic/163821-r34-gtt-engin-light/
the check engine light will come on to indicate knocking/pinging...its not good. The factory warning is set to come on at 60, which is pretty high...tuners like to keep it under 20 when tuning aftermarket ECU's
If its only happening in 4th or fifth gear, I'd say you're in the wrong gear to be accelerating that hard at the time, and putting too much load on the engine. if you were to drop back to 3rd and accelerate that hard, chances are you wouldn't get the knocking as it sounds like your car is fine the rest of the time....
Have you got an after market ECU and a tune? or still on the stock ECU?
Either way, its not good, so I wouldn't keep doing what you're doing...take it somewhere and get it checked out :stupid:
Guest Joeyz
I'v only had the car about 6 weeks and know that it has a APEXi Power FC.
You said that the car might be knocking, I can't hear any noises like that. I used to be a mechanic about 4 years ago and i'v heard what that should sound like and i can't?
I never worked on car's like this before or up untill i bought it.
I do have planed to take it to a dyno and get it tunned fairly soon though.
you don't have the pfc hand controller do you? umm I seriously think there's a flaw in 34s pfc....I've heard ppls pfc sorta "detune itself" every few months, initially knocking at 5th then move down to 4th ..etc..
agree - definately knock
note ur load speed revs and gear to help the tuner out
i'd also consider in investing in the handcontroller (while they're still available)
feedback info on display very usefull (such as knock and water temp)
goodluck with it
Guest Joeyz
Nah don't have one. Looks as though the previous owner didn't have one or sell it with the car. When you say hand controller is it conected to the PFC or not? Never seen one.
I suppose E-Bay or buy one brand new for the car?
I noticed this problem myself, except my engine light flashes very rapidly at the end of 1st and sometimes 2nd. Only saw it happen once or twice though, apparently the owner who I bought it off said his car would knock alot too. Is this a common R34 problem or could it be something on my end? As in the unit itself or the actual knock sensor?
Guest Joeyz
Hi all!
Thanks to all that replied about the engin light.
I was able to get my car dyno tuned today by Castle Hill Exhaust and he brought back the timming a bit so the light would not come on. All is good now! Yeah!
My car started at 178kw and the final outcome of the tune was 199.9kw at the rear wheels. Very Pleased.
Thanks again :P
Hi all!
Thanks again :P
What sort of work has been done to the car to acheive those figures?
Hey mate...I wouldn't be running 15psi through the stock turbo...unless you want it to fail and have to replace it.....generally the safe limit for them is about 12psi...you might find you'll make more power on lower boost too....I make 200-205rwkw with the same mods on an R33 at 12psi...
Guest Joeyz
It has a front mount intercooler, 3inch exhaust all the way through, Apexi power FC computer, K & N Air filter, HKS Blow off valve.
When dyno'd on saturday, it was running at 1 bar and now it has been adjusted to 15psi.
Guest Joeyz
I don't understand how i will make around the same power running less boost :thumbsup: can you tell me how that is?
I still am learning a lot about the car, only had it 6weeks.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
