your not going to stick with the the 3 litre or u got bigger and better things on the cards?
Well i must say the 3L /4wd combo is exceptional and people dont realise how much torquer the 3L twin cam is over say an rb26, i dont think i could ever drive anything but a 3L again it just wouldnt do me justice! :P
https://www.sau.com.au/forums/topic/164464-sold/#findComment-3082423
Well i must say the 3L /4wd combo is exceptional and people dont realise how much torquer the 3L twin cam is over say an rb26, i dont think i could ever drive anything but a 3L again it just wouldnt do me justice! :domokun:
so any hints then as to what your going to be doing?
https://www.sau.com.au/forums/topic/164464-sold/#findComment-3083154
will u seperate intake plenum
Yes for the right price, intake plenum comes with borred out tb, modified coolant hose, modified coolant apparatus, aac valve modified, custom accelerator cable and all bits and pieces needed to bolt it straight on!
https://www.sau.com.au/forums/topic/164464-sold/#findComment-3089426
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
