  • Replies 67
stasis - thanks mate, i have a few mods in mind but i just need to save for a little while before i do some more spending
Duncan - YES :P:O:( thats awesome, so many targa cars on the road, my mate said "hey check out the skylines, probably heading to the targa tas.... holy shit theres a stagea with them!!" thats the best :)
yokotas13 - yeah mate i have some great wheels ready to go on :) im just wanting to get through the slip's with the standard wheels
Wildcat - hehe thanks :) i wouldnt say that im a yellow lover but i think its really suited :)
yokotas13 - they are Australian made ROH 3 piece modena's, this is the only picture i have of them right now but ill get plenty more once they are on, weighing in at 6kg each from memory.. the only drama im having at the moment ( as Joe pointed out to me a little while ago) is that being a RS4 you are meant to have all wheels the same width, where these wheels are 18x8 and 18x9.. but on the same token i have spoken to other people who own GTR's and one stagea owner actually with a RS4 who run different widths and say that they have never had a problem.. if it dose prove to be a problem then ill get some new outer rim’s made up so they are all the same size.
joe26f - haha yeah mate it has taken a while hey, pretty happy now but :closedeyes: once its rego'd next week ill have to show you :)
AlexCim - yup sure did buy it from Alex, i was very tempted to get the nismo wheels but didnt because i have had these modena's sitting in my garage for ages, so i thought i would save a few dollars and put the one's that i already have to use
Nice car, Bryce.
Those wheels will really set it off. As far as the different sized wheels goes, just make sure that the rolling diameters of the wheels on the front are the same (or as close as possible) as the back ones. The different rolling diameters is what stuffs up the ATTESA system and burns out clutches, etc.
GoldZilla - thanks mate :D all 4 are the same diameter, same make etc the only differance is the width.. so it should be right :angry:
WELL it didnt take long for things to go pear shaped :D i spent all day cleaning the car and just generally getting it ready for the slips tomorrow, all was great and i parked it in the drive way. it came time to put the bins out the front so i got in the stagea, drove it out the front ( so that i could get the bins out the front without hitting the car) as i drove it out the front i put the foot down alittle bit (as you do) the tacho reached around 3000-3500 and it started to cut the power, it almost felt like a vicious rev limiter.. i experience something similar in a falcon when i put a new engine but i cant remember how i fixed it.. any idea's? any help would be great :thumbsup:
Edited by Brycey
Did you clean the engine bay? Sounds like you might have got the coilpacks wet?
It might pay to pop the cover off and make sure you don't have any water pooled in there.
I had the same problem after dropping a new head on a falcon 6 but it turned out to be an issue with the distributor so no help there :bunny:
i hosed down the engine bay alittle bit, but i wouldn’t have thought that the coil packs would be the issue, i was more assuming vacuum lines or something box related.. but your probably right ill have to check it out in the morning, hopefully its something simple like that :bunny:
joe26f - haha yeah mate it has taken a while hey, pretty happy now but :bunny: once its rego'd next week ill have to show you :P
i ran 9/10s
no problem other than some rubbing ont eh rear coilover
but i also had 225/40s and 235/40s on them, so it evened out the rolling diameter.....but it didnt make a difference
Another Hunter based Stagea, good stuff, theres not many Stageas around here yet.
Looks sweet mate, we'll have to organise a meet sometime.
Yep, you ALL need to come down to the SAU-NSW Show and Shine in June...
I need some other people to help me "reprezent the Stagea Massive, y0!"
it didnt take long for things to go pear shaped : the tacho reached around 3000-3500 and it started to cut the power, .. any idea's?
Dude it sounds like you did exactly what I did on day 2 of owning my Yellow S2 - washed it. It is guaranteed that you have water in the coil pack 'valley' and also in the airbox.
Removing the silver engine cover is easy enough, but the black plastic coilpack cover is a real bugger as you will have to remove the intake pipe that runs across the engine. But if you could lift it up at one end and blow it out as best as you can it should help. Dont think you can wait for it to dry out, it can take days.
However the most likely cause of the miss fire at 3000rpm is from water in the bottom of the airbox. Because it works in a downward direction as opposed to VL Commodores, the water pools in the bottom just below the AFM intake. When you get enough suction happening (at higher revs) it will suck some of the water in.
Water per se going into the engine is not a problem, but the hot wire AFM will be upset when it makes contact with the water.
PS, the colour yellow is special, I just had to have it when I saw mine, but there are times when I wish I could turn 'the volume' down a bit, especially when I'm in the mood for a bit of spirited driving...boost surge is addictive.
3intheBack - sure enough, there was a big pool of water at the bottom of the box haha, so thats all sorted :down: yeah yellow is special but I know what you mean about the “volume” of the colour when it comes time to being inconspicuous :huh:
got the blue slip (all went great) and the green slip yesterday, i walked into the RTA and everything was still going great, she gave me some plates etc, photocopied a few trillion sheets of paper.. then at one stage there was a slight pause, and she said in a "surprised" yet sarcastic voice "it looks like your car has been selected!", my first thought was "mad, what did i win" but it turns out i won a trip to the pits for a complete number check etc to make sure nothing is rebirthing.. but thats not why im annoyed (because i know the car is legit) im annoyed because yesterday was Monday and she booked it in for Friday! i asked "can i drive it between now and then?" and she said "yes!... *5 second pause*... to the pits at Carrington." then took the plates away :D ..
so, the stagea looks very pretty in the driveway ;)
one thing i want to get sorted out this week is the different size tyres, im obviously keen to get them all to the same rolling diameter.. ill have some new pics up soon :down: cheers
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
