I finally got all my parts needed to do the rebuild. All parts are supplied by me.
Wiseco 40thou pistons + rings
Eagle H beam rods + rod bolts
ACL big end + main bearings
1.2mm HKS headgasket
Tomei Poncams
Heavy duty valves
Headstuds
N1 oil + water pumps
HkS timing belt
What workshop do you guys reccommend to do the job properly? Everyone seems to think that the only workshop in perth is Xspeed..Interested in feedback and experinces from other places. Any ideal or ball park is to how much much it will cost? I want maximium reliablilty and it all crack and pressure tested, x-rayed and complete bottom end balanced.
https://www.sau.com.au/forums/topic/164605-r34-neo-full-engine-rebuild/
  • Replies 44
well basicly because they build high horsepower engines that last... whats the point on spending $20000 to see it last 4 months, mines been goin strong for 18 months and not missed one tick.... they let their engines do the talking for them.... give john a call, mad not to..
you might as well just look at the consolidated workshop thread once again
seriously this thread will go no where we have all got our favourites and thats that
im sure the big names in perth will all do a pretty good rebuild , its not rocket science
Edited by arkon
Tomei Poncams
Heavy duty valves
Headstuds
HkS timing belt
u seem to know what you need to get a good RB going(judging from list), someone recommended all these parts to you or you knou your stuff. maybe you should ask the same person to recommend a workshop to you or you already know the answer to your own question.
I really didnt think this thread could last 10 and a half hours ha ha
Check the consolidated workshop thread, ring around, find someone you are comfortable and trust, then give them your parts. Cost should not play a huge part in a build like this.
mayb wen u spend $20k on ur engine.....looking for a workshop to do a good job/price would be of use to you....But in ur case....installing a pod filter then i surpose any old person would do
sarcasim is not one of your strong points obviously
or mine perhaps......
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
