and their high magnitism towards police cars
I'd say it was the other way around. Police cars are magnetised towards Skylines, not the other way around.
Skylines are more magnetised towards telegraph poles and kerbs.
  • 10 months later...
im a bit late for this post.. but rb25 rods are knowed to have week bolts for the bearing cap.. ( where they fail) any one got any ideas what they could handle as i have had mine shot peened and arp bolts fitted..
ive never had any drama's.. even with atmo bov's
it has been a dream.
fuel consumption is good. 350-400kms per tank.
weakness is probably the wheels, tyres, clutch, diff. upgrade and your set.
BUT.... i have had to replace a few components, just as a maintenance thing. be prepared for belts, 02 sensor, aircon regas, tyres, LOTS of good oil and maybe some electronics.
AND I HATE THE BLOODY R200 diff. bloody single spinner. so shim that up aswell.
My family has owned 3 Skylines:
2001 R34 GTR
1997 S2 R33 GTS-T (202rwkw - Basic mods)
1997 S2 R33 GTS-T (255rwkw - Quite heavily modified)
Main weaknesses i have found so far are:
- stock clutch on R33 (needs changing at around 200rwkw)
- stock turbo on R33 (needed changing 1 month after raising boost)
- interior build quality on R33 (generally not bad however bland and prone to rattles)
- expensive parts and maintenance on R33 & R34
- stock suspension on R33 (was too soft and needs to be upgraded)
- MFD screen on R34 (sometimes would have a red line down screen when first turned on)
- tyres on R33 & R34 (good tyres are needed to fully exploit handling, particularly R33, and get expensive especially with bigger/wider rims)
Strengths include:
*Diffs and gearboxes have been rock solid
*Stock engine internals will reliably handle heaps of power
*Brakes are strong with good pads but can be prone to squealing
*So many other things I don't have time to mention
well when i bought my R32 gts-t it had a bad airflow meter and the transmision oil was black and the brakes where gone and the engine fuel was gone and the radiator was leaking and the sparkplugs were dead the tyres were bald and guess what the car beat a v8 and goes as hard as hell like there is no problems in the car. mate these cars can handle alot of abuse and the car still goes. when i went to the mechanic he said how did u drive this car here? it should have a blown engine by now but it didnt, after alot of fixing and tuning the car is now a monster. i have to say the skyline engine is the strongest engine i have seen. japanese people know how to build there cars :D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
