and their high magnitism towards police cars
I'd say it was the other way around. Police cars are magnetised towards Skylines, not the other way around.
Skylines are more magnetised towards telegraph poles and kerbs.
  • 10 months later...
im a bit late for this post.. but rb25 rods are knowed to have week bolts for the bearing cap.. ( where they fail) any one got any ideas what they could handle as i have had mine shot peened and arp bolts fitted..
ive never had any drama's.. even with atmo bov's
it has been a dream.
fuel consumption is good. 350-400kms per tank.
weakness is probably the wheels, tyres, clutch, diff. upgrade and your set.
BUT.... i have had to replace a few components, just as a maintenance thing. be prepared for belts, 02 sensor, aircon regas, tyres, LOTS of good oil and maybe some electronics.
AND I HATE THE BLOODY R200 diff. bloody single spinner. so shim that up aswell.
My family has owned 3 Skylines:
2001 R34 GTR
1997 S2 R33 GTS-T (202rwkw - Basic mods)
1997 S2 R33 GTS-T (255rwkw - Quite heavily modified)
Main weaknesses i have found so far are:
- stock clutch on R33 (needs changing at around 200rwkw)
- stock turbo on R33 (needed changing 1 month after raising boost)
- interior build quality on R33 (generally not bad however bland and prone to rattles)
- expensive parts and maintenance on R33 & R34
- stock suspension on R33 (was too soft and needs to be upgraded)
- MFD screen on R34 (sometimes would have a red line down screen when first turned on)
- tyres on R33 & R34 (good tyres are needed to fully exploit handling, particularly R33, and get expensive especially with bigger/wider rims)
Strengths include:
*Diffs and gearboxes have been rock solid
*Stock engine internals will reliably handle heaps of power
*Brakes are strong with good pads but can be prone to squealing
*So many other things I don't have time to mention
well when i bought my R32 gts-t it had a bad airflow meter and the transmision oil was black and the brakes where gone and the engine fuel was gone and the radiator was leaking and the sparkplugs were dead the tyres were bald and guess what the car beat a v8 and goes as hard as hell like there is no problems in the car. mate these cars can handle alot of abuse and the car still goes. when i went to the mechanic he said how did u drive this car here? it should have a blown engine by now but it didnt, after alot of fixing and tuning the car is now a monster. i have to say the skyline engine is the strongest engine i have seen. japanese people know how to build there cars :D
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
