hey guys,
I'm just wondering who with r34s on here have experienced bad coils? I've searched around and found problems with a missfire in the 4000 to 4500rpm on turbo cars but what do NA symptoms have? how can u tell its a coil and not a plug without physically inspecting it? reason I ask is mine is running like a dog (sounds like a WRX) and there is a lot of stuff to unplug to get to the cam valley to check.
so any help on what the symptoms are would be great I suspect its a coil but need some reassurance.
thanks
https://www.sau.com.au/forums/topic/164961-bad-coils/
NA's with bad coils experience the same problems as their turbo counterparts. My last car was a ca18de and i went through about 12 coils on it. Car feels like it's missing a cylinder and sounds like a wrx but without any pull. There's a few threads on coil maintenance and cleaning, check them out.
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3056087
Also can anyone tell me it is a coil from my symptoms?
Cold start is fine will drive around OK for a long time or short time its totally random. Engine light comes on car sounds like a WRX has poor accelertation etc. But when it is driving OK it does have a miss as well?
Any help would be great
Cheers
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3056886
Generally speaking, nissan coils generally get worse when they're hot. On my previous car, when the coils were bad they would generally be okay for about 30 minutes then it would sputter and the engine light would flicker as you say.
How many kms has your car done? has it ever had the coils replaced? I would definately give it a good clean, take out the carbon deposits on the tip perhaps give it a light sanding, silicone the boots and clean the leads. Come back and tell us if that helps solves your problem.
Investigate the possibility of going to splitfire replacement coils... I wish I had known about them earlier, that would've saved me going through a dozen coil packs.
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3056997
Thanks again Howie will give that ago. Car has done 60,000k's Can they go around there? I have heard R34's are notorious for coil failure.
My first set went at 68,000kms on my last car.
It's not just R34 notorious for coil failure, it's basically any nissan car pre-2001 that uses the coil pack system. CA/SR/RB's.
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3057103
ive had my r34 for 7 months and had 3 coils go on me. in the end i replaced all of them with splitfires. its too costly too continue to replace each coil as they go. my r34 n/a has done 67,000. the last 2 times i lost the coils the car would be running on all 6 cyclinders, then lose a cylinder then gain it back etc. those two coils where showing a greater heat resistance to the others. hope this helps!
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3057915
  • 4 weeks later...
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
