Finally got to the drags this weekend, unfortunately it didn't go all to plan,
the car had a massive boost leak, first run on 19psi(with the boost controller set to 26psi)
the car went 10.67 at 132.94 with a 1.77 60 ft, we coudn't fix the boost leak so turned up the boost controller
to 25psi manually(so the turbo was probally pumping out around 35psi to make 25 in the motor), then the
transbrake woudn't work. So i stalled it on the brake pedal, rolled out for a 1.68 60 ft and ran 10.21 at
140.9mph, all on pump fuel/ full exhaust and at least 20rwkw less than i usually drive it on the street with.
Car didn't use a full slick either , just a m/t street grooved slick that i have been driving round on.
So CTIFLY record has FINALLY been broken.
There a lot more left in this combo, if the transbrake worked it would have gone 9 something on that pass
and theres another 50rwkw left in the tune on pump fuel and 26psi still, unfortunately the stcck bottom end
finally went bang..the alternator failed and the voltage dropped to 7volts, killing the fuel pumps
and altering the injector pulse width....time for a decent forged motor
cheers
darren
video -
Hopefully you got some better traction there on the Sunday after two days of rubber being laid.
Heaps of traction problems for the serious cars there this weekend.
That thing is a weapon, and it's only a matter of time for the 9.
If we'd known you were going to be there racing, Nightcrawler and myself might have hung around to see you run.
There WAS a 9 run there by a blue skyline that weekend though...
cross ply et street, i haven't much faith in the radials, as my set for the street in 17's are
are joke and they wear quicker, 4 nights with just roll ons, no wheelies and they were bald,
not good value at $640.
The block/rods etc are all fine, sounds like i broke a ringland on one piston, still starts first go and drives,
just not on all cylinders:)"
cheers
darren
just a shame you couldnt catch the cressida!
and his engine is still running strong...
just stirring...
good effort.
lol yep Jays running on a fresh motor.. Already done one in. :closedeyes:
What times did Jay run? Jake was out there also?
Obviously detonation killed the piston. A bastard the alternator let go. :)
All in street trim, daily tyres etc.. Top work Darren.
lol yep Jays running on a fresh motor.. Already done one in. :P
Obviously detonation killed the piston. A bastard the alternator let go. :(
10.1 at 143mph
Jays "fresh" motor is still just a stock bottom end.
it goes to show that both nissan and toyota 3ltr bottom ends can pull some good numbers
10.1 at 143mph
lol yes.. I believe his origional motor let go due to a fuel pump/lean out issue also. :P
But definitely tough as bottom ends.
Jay run on slicks or similiar tyres to Darren? Great effort from the 5speed.
cheers
darren
video -
btw...where's thedrag strip? is it in adl? open to public?
i thought adl only has AIR
10sec car :)
lol yes.. I believe his origional motor let go due to a fuel pump/lean out issue also. :)
jay ran on full slicks, race fuel, no exhaust, bloody good time for a manual!!,
i think they are going back for 9's soon.
jake went 10.3 at 136mph with one pass then blew the trans, that will be easily in the 9's
in a couple of weeks aswell!
I personally have no interest in race fuels,no exhaust etc, i want to know how fast my car runs how i always
drive/drove it, and it makes it interesting,anyone can tune a car on race fuel, it's full proof, wind the compressor till
it noses over, set timing for peak torque, walla, no balancing act.
the car would easily go upper 140mph traps with those mods and well into the 9's setup
I had 1 pass on fullboost, if the motor lasted it would have pissed in a better time..but shit happens:)
next time:)
cheers
darren
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
