ROFL i was hammering it down the m5 when i approached the toll gates near liverpool, and my car stopped and wouldnt start, getting my gf out to push the car into the m5 toll parking lot and then checking the radiator hoses the clamps loose and the hose popped off with no water there and an heated up rb, fkn hell, worst off all no screw driver to pop it into place again, quick call to the old man comes and helps me put it all together again, fill it up with water (no coolant on the spot) and back on the road at 10.30. problem is i dunno how long there was no water, and the water temp gauge showed no sign of movement whilst i was driving unless it poped off when i slowed down, oh wells, DID I RUIN MY ENGINE? if so oh wells rb30 here i come, if not damn gonna have to wait until i get a new excuse lol
Also now that i noticed the idles a fair bit rough, and sometimes when coming to a stop at lights put it into neutral and the tacho goes under 500rpm then bounces back up to around 700 (which seems low to me?) also the water temp gauge shakes up and down sometimes, i still havent had time to put coolant in there, is it because im running just on water at the moment........ HELP ME! i hope i havent cracked my head or blown my head gasket. what i did when i put water in the radiator, started the car the slowly filled up did i stuff it up... fark i cant even remember wat i was doing coz i was so gutted
Edited by DaGr81
https://www.sau.com.au/forums/topic/165001-radiator-problems/
any oil in the radiator....or bubbles come out when you take the cap off whilst running??
Water normally cools the engine better then a water/glycol mix. But straight water obviously boils at 100 and freezes at 0(not that it applies to us) and it rusts all things of a ferrous nature. But alot of people run straight water...with a light mix glycol.
Water/glycol/water wetter :)
Do a reset of your computer while you are at it, I have heard the computer will take out timing/muck around with settings when it gets to a high temp.
Although white smoke doesn't sound too great.
I had all the water disappear because of a cracked end tank on my radiator, didn't notice the needle move either (have heard R32 temp gauges are useless at high temps). My car also stalled when taken out of gear once I noticed it was overheating. Had a CO2 test done (I think that's what it's called) and all seemed fine, and has been fine, for the last 3-4 months. Guess I caught mine before any real damage set in. Was an RB20det though...
Get a Co2 test done I guess.
Fixxxer
all fixed thanks to advan, no damage to engine, now blown head gasket or cracked head/block, reason for the water temp gauge moving up and down was an air pocket in cooling system which can be fixed through the head (i'll have to post a photo about this) not sure how many people do this when doing a cooling system flush as i havent seen it mentioned in a radiator flushing guide. radiator hose clamps replaced with heavy duty items. cheers to everyone who put in their opinions and the boys at advan
Everyone knows about that little bolt on the plenum, it is the air bleeder with a little warning in jap next to it that.
well it wasnt mentioned in one of the diy threads so i thought some may not know about it hence i said "not sure how many know about this" you cant assume everyone does coz im sure not all know about it ta
fkn hell, the temp gauge still flicks up and down, but once it gets to operating temp (80 - 82 degrees) its fine, what to do, if i was to just bleed the air would it be fine and then top up the coolant if necessary? or should i take it back to advan see if theres any other thing that could be causing this...? advice peoples (im no genius on these things lol)
I say damage has been done :nyaanyaa: no good, in that time you would have done something either warped the slightly or something, something of that nature associated with not running water in radiator and the car just stops?? How did they ascertain that there was no damage, did they do compression tests at all? Oh btw the temp guage wont move even if you lose all your water in the radiator thats why its so hard to know if you have no water in the radiator whilst you are driving oh another way to remove air pockets
Start your car with radiator cap off
wait till it is upto operating temp as in the temp when the thermo opens
watch the bubbles come out and water go down top up until once the water freely flows over the edge of the radiator thats a neat trick aswell for those who havent got one air remove thingy
I say get a compression test done it wont hurt or leakdown test wont hurt either.
Ecu reset for that other thing? I say why you shouldnt have too touch that...
hope its all good
Cheers
A
will do that one...cheers, but nah what they did was check the oil (see if it was creamy) check for smoke from exhaust, check pfc, check idle and rev the engine, but they said you'd know if you have a blown head gasket or cracked block etc etc
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
