  • Replies 41
Yes, they are parallel imports, and production date is 04. They should have a 3 yr life on the rubber, which is why he is selling them at reduced prices
According to the Toyo website, the tyres are only good for 12 months and they specifically warn about buying parallel imports.
The "shelf-life" of the "GGG" and "SG" tread compounds is considerably shorter
compared to the compounds imported by Toyo Tyre & Rubber Australia Limited. The
majority of the parallel import Proxes R888 tyres in "GGG" & "SG" tread compounds were
produced in 2004. Performance of the "GGG" & "SG" compounds will not be as the
manufacturer intended where tyres are more than 12 months old. This is one reason why
Toyo Tyre & Rubber Australia Limited keeps very limited stocks of Proxes R888 "GGG"
tyres.
Perhaps the price should be a bit better considering the reduced performance?
picked up 2 of the r888 in 16's extremly soft tyre compound. mate u wana bust the price down. i think less then 150 for any semi slick is a deccent price, pretty much similar price for a normal road tyre in 225 40 16. taleb's was very helpfull also.
  • 1 month later...
  • 3 weeks later...
Hi there Im also interested in a set of 255/40/17's. Im pretty sure the 235/45/17 would be a bit narrow on 17x9.5 rims??
Cheers Andrew
OK here's a list of people interested so far for 235 40 17's and 255 40 17's:
Trust33
Forged
Betz
woolls
padey
r33-d-rift
Adriano
kyle785
Price will be found out as soon as possible.
  • 3 weeks later...
  • 7 months later...
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
