  • Replies 86
Posted Images
On call 24/7 Xmas & NYE - Sunshine Coast
On-screen credit
Socially responsible project
It is going to be tough with long hours and being on call 24/7, but our project is worthwhile.
Young people are continuing to die at an alarming rate on our roads. How many will die this Xmas?
You could help to save a life, and gain experience and production skills.
Payment is $1,000 - $2,000 for the ten days depending on experience. If you have your own equipment (camera), we can negotiate for its use.
We can provide basic accommodation and a guarantee that you will have a good team to work with.
We are looking for a reliable committed person with some experience in video camera work and possibly post-production. You will need to submit some show-case material.
We are based in Maroochydore on the Sunshine Coast Queensland.
Loraine McElligott
Westwood Enterprises (Qld) PL
BH (07) 5443-4500
FAX (07) 5443-3343
oh god.. these guys really are on a misguided crusade aren't they..
They've got another ad going too..
Video Editor - Sunshine Coast
Roadside Watch is an internet-based service designed to assist in reducing the road toll. Based on the Sunshine Coast.
Contract video editor will require their own editing software and computer.
Separately, a short dramatic promo also requires editing.
Opportunity for further work in editing / video production down the track.
Project must be completed by Easter Thursday.
Loraine McElligott
Roadside Watch
PO Box 111
Cottn Tree 4558
Email: Please click the 'Apply Now' button below.
I might give them a call and let them know prevention is better than stalking. Maybe they should train drivers... Make a driver training facility up there...
But yeah, thats gold.
"hoon removal kit" http://www.roadsidewatch.com/use/server.php?page_id=4208
These people really aren't too intelligent are they?
# McElligott L
# 86 Beach Pde Maroochydore 4558
# (07) 5443 3343
btw: well if they're going to claim 'public interest' for filming people without their consent, so is the above..
in the "roadside watch policy" part
they liken hoons to gunmen wandering the streets lol oh my god, wtf are these ppl doing.
QUOTE
5. Report it. If you saw a madman in the street with a gun, you would not hesitate to call the Police. If you see a madman in a car endangering the lives of others, take a video and send it to us. We will forward it onto the Police. Don’t let someone kill the ones that you love, just because no one bothered to slow them down.
Edited by 85URK
# McElligott L
# (07) 5443 3343
Is this the ring leaders addy?
a removal kit...
i was just going to say this setup would be sweet to record some in-car footage at a track day... but $1500!!! fark that.
Technical Specifications
Electrical
Voltage 8 to 40 VDC (12 VDC Nominal)
Power up to 1 W (not including cameras)
Battery Pack 9.0 VDC 700 mAH Rechargeable NiCad
Video
Inputs 4 Female RCA Connecters
Outputs 1 Female RCA Connecter (for setup and live monitor)
Type NTSC Composite Video
Image Resolution up to 360 x 256
Frames per Second up to 10
Recording
Triggers 3 NH and 3 NL inputs (3 negative and 3 positive inputs)
Medium up to 1 Gigabyte Secure Digital (SD Card)
Pre-Event up to 2 minutes (varies +- based on resolution and frame rate)
Total Duration varies based on resolution, frame rate, and SD Card size
Physical
Dimensions 6.1 x 4.2 x 1.5 Inches (Main Unit), 2 x 1.0 x 0.5 Inches SD
Weight 1 lb.
Operating Temp. -40 to 70 C (-40 to 160 F)
Connections +12 VDC, Ground, Ignition, Power to Cameras (x4),
Camera Inputs (x4), Video Output, SD Card Pod, Triggers
EDIT: actually they're pretty crap cameras
QUOTE
I gotta say, Id also report some freaky barstard out the front of my house with a camera sitting in their car for 3hours!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
