hey guys im i have a rb26 that is being machined and im trying to figure out if im going to run into problems with CR ratios.
what i have is
supertech 87.5mm forged pistons
eagle h beam rods
about 12thou machined of the head
and the block is being decked (so we can run the cometic gasket)
1.2mm cometic mls gasket
info on the piston spec sheet is
bore size-3.4055/86.50mm
compression height -1.181 (30.00mm)
dome height/dish depth -+0.1378(+3.5mm)
dome/dish cc's - +15.5cc
is there a program i can use to suss out what cr ratio i will have once i find out how much is taken off the block?
and am i going to run into isssues with piston to head clearances?
thanks guys
johnny
https://www.sau.com.au/forums/topic/165055-what-cr-ratio/
  • 4 months later...
whats the better option....to pick a gasket thickness to suit your desired comp ratio....or deck the head instead? Providing both options use the same pistions?
I have wiseco 40thou and 1.2mm gasket...going by their website, this will give comp in the 8.3 regoin....But i have a NEO which i heard have bigger combustion chambers.....giving even lower comp?? Shoudn't have any problems with decking the head?
https://www.sau.com.au/forums/topic/165055-what-cr-ratio/#findComment-3307877
I think its the other way round ovabooster, neo heads have smaller chambers. So that would result in a higher cr. Unless im getting mixed up.
cr calc http://www.csgnetwork.com/compcalc.html
Edited by r33_racer
https://www.sau.com.au/forums/topic/165055-what-cr-ratio/#findComment-3307887
Depends on application. Alot of people use the headgasket as a way of achieving their desired comp ratio, which i dont think is the best way to go because you stuff up your squish. Really you should be using the pistons and machining to achieve what you want and keeping a similiar sized gasket to achieve a good squish of 40-50 thou. Its all based on everyones own personal opinion. Need to be careful how much you deck too, alot of builders dont like the piston protruding out of the bore and into the chamber/gasket a great deal. Plus piston to valve clearance and blah blah blah. More then meets the eye.
Find out roughly what your chamer cc's up to and put in your piston specs and whatnot into the calculator and work it out. But first what cr do you want to achieve?
https://www.sau.com.au/forums/topic/165055-what-cr-ratio/#findComment-3307921
yeh i would be aiming for 9:1 but 8.8 would be close enough i guess. Alot of time when you work it out it could be out by .2 either way especially if the chambers are not cc'd and just guessing based off std info. If you have your piston spec sheet, you should be able to work it out with the calculator. Just play with the values until you get what you want and then you will know whether you wanna change gasket or machine.
https://www.sau.com.au/forums/topic/165055-what-cr-ratio/#findComment-3307945
There is no guessing when it come to compression ratios. There are so many variables involved. So many people buy pistons off the shelf and believe they will end up with the comp ratio that comes with the piston spec sheet.
There is only one way to calculate it ( it is time consuming and complicated ) and that is why most people and many engine builders evoid it.
Cc'ing piston dome / dish volumes, deck heights ( positive or negative ) , piston valve reliefs, compressed head gaskets ( not the stated thickness ), combustion chambers.
So you can guess, estimate and calculate - but unless you have all those precise measurements you are just walking and talking blind.
https://www.sau.com.au/forums/topic/165055-what-cr-ratio/#findComment-3308055
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
