The only place ive seen that has an aftermarket metal intake pipe (metal is meant to make the flutter echo and sound better) is on the nengun website Apexi have a full intake kit for the r33gtst and possibly 32 but im not to sure.
Only prob is its like $300 but it does include everything you need and the pod filter too
https://www.sau.com.au/forums/topic/165074-bov/page/2/#findComment-3060732
  • Replies 46
i got mine from Shy180 on the forums too.
Hey Cubes, what type of metal did u use to block the bov? and what did u do to block the vac line?
im considering doing this after what ive read here :P
Edited by Sambo33
https://www.sau.com.au/forums/topic/165074-bov/page/2/#findComment-3061070
While on the bov question. My car I just bought has 2 bov's in place :P as seen below:
I want to remove the aftermarket one, so I bought a new stock cooler return pipe (black pipe). I was going to replace it today, but then noticed that the vaccum line has be re-routed to the aftermarket bov, and the stock bov has the pipe where the vaccum attached removed/blocked with a screw!!
SO, can I replace the cooler pipe to remove the aftermarket BOV and just block the hose from the manifold?
How does it affect the operation of the factory BOV if it doesn't have a vaccum/boost reference?
If you dont block this hose, does this not cause a boost/manifold leak?
Cheers for the help
Edited by Hotwire
https://www.sau.com.au/forums/topic/165074-bov/page/2/#findComment-3065351
You would want to use the stock bov if you dont have an aftermarket ecu of some sort because the stock ecu has been programmed to run with a plumb back bov so not having one will make your car run richer at certain times (ie gear changes) just run the vac source back to the stockie bov
and yes if you didnt block the boost/vac source it would cause a leek
Edited by /2on
https://www.sau.com.au/forums/topic/165074-bov/page/2/#findComment-3065728
Sambo33, it sounds so much better with the plate there :P. I'm going to get the intake pipe this week hopefully, otherwise might just pm shy180, how much did people on here pay for just that pipe usually?
yeah i blocked it off this morning, lots of chatter now! haha. i took it for a quick drive and everything works fine, no stalling ect. i couldnt really open up the throttle too much (being in the city and all) but i think it feels a bit more responsive than before.
i cant remember what i paid for the intake pipe, ill try and find out.
https://www.sau.com.au/forums/topic/165074-bov/page/2/#findComment-3074099
  • 1 month later...
