Sent my RB25DET 180SX for a dyno run yesterday after having run the new engine in for over 5000km's. it was running the stock RB25DET AFM, but I couldn't install the Z32 plus tomei plug until it got tuned yesterday.
The GT30/40 turbo is installed and the car at 1.2bar is making 190kw but the Z32 is maxed out at 5 volts already. The car drives perfectly fine but the AFM is maxing out for some reason so early. The setup is using a Power FC with AVCR, and apexi air filter. 720cc nismo injectors and Tomei 270 fuel pump
Any suggestions as to what could be wrong? it's the usual orange stickered JECS item (22680 30POO A36000 N62).
https://www.sau.com.au/forums/topic/165286-brand-new-z32-afm-problem/
  • Replies 106
Posted Images
Yeah it can make a lot more power, but because the AFM is showing 5 volts it's maxed out and that is the point of this thread - to determine why it's maxed out so early.
The dyno is one of the lowest reading one's in Brisbane, a few people i know have taken the car for a power run at other shops straight after and read 30kw extra at the wheels. The car only feels fast to me because i've done a 5000km run in with no more than 4000rpm the entire time.
How many people have purchased a new Z32 AFM and found it to be faulty straight after install? I've done a search but haven't found any posts on this here.
Cubes - Correct me if i'm wrong, but should a boost leak have anything to do with the voltage of the afm? metered air being drawn through before the compressor is it not?
My mechanic also mentioned that this could be one of those copy AFM's, it was bought through a sponsor on this site, and looks identical to the ones pictured in just about every search result i found tonight.
Of course it will... If you have a leak in the system the turbo's going to be sucking and compressing a lot more air than if there wasn't a boost leak. So the afm will read higher, not sure if its possible for it to read this much higher though. :S
whats AFM1 value at idle?
when you rev it a few times does it return to the same value?
have you checked for any piping leaks?
are u sure the car is dynoed correctly? not 3rd or auto or something obvious?
what rpm is it maxing at ?
Isn't there some dodgy china copy z32's getting sold now. I had first hand experiance with one and heard of another here in perth.
No, there are no "China copy" AFM's on the market - That really is a stupid rumour :nyaanyaa:
As far as I can tell, there was an early batch of Bosch AFM's that had some problems. I bought a pair of them for my GTR and when I discovered that they were misbehaving during tuning I contacted the shop I purchased them from and they confirmed that the issue with their behaviour was a known problem and had been taken up with the company that supplies many dealers in Australia.
Both of them were promptly replaced under warranty without question :domokun:
Dodgy afm i say or incorrect setting in tune used ie: set to use standard default afm, not set to z32 wouldnt this cause an issue aswell?
selecting the wrong AFM or using the wrong AFM ramps will give screwy results on the load axis map and tuning but wont make it max out.
ie: if the afm is reaching 5v then its measuring as much air as it phyiscally can. what the ecu does with that value is upto the ecu.
the ecu logic for airflow ramp and control is done after the signal is read in
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
