I have done a bit of searching and found that all the rebuilds done on an rb26 are to beaf them up. What I want to know is what is invloved in rebuilding a standrad r33 gtr motor back to standard form. And roughly how much it would cost. Including labour and excluding labour. Has any one rebuilt their gtr back to standard.
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/
  • 2 months later...
As of 26/06/07 I have had the engine pulled apart. Found that piston 6 was missing a section so I decided to have it rebuilt. I was wanting to rebuild it back to the standard specification but this did not seem feasable as standard gtr pistons from nissan are over $2000. So I went with a set of oversized forged JE pistons. The motor is currently being rebuilt and will hopefully be finished by the end of the week.
Total known costs to date:
-Pistons , $1660 with rings inc
-Labour to have block pulled apart, honning of all bores and pistons attached to original conrods and a gasket kit, $1000
-Engine removal $unknown
-Engine reinstatement $unknown
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3198630
I'd budget around 7-8k safe, the gasket kit, headgasket, pistons, bearings, block and head work plus labour will pull upto to that easy, not to mention a clutch or ecu ..
I did the works on my gtr cost near 15k...
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3198877
you are better off selling your engine to someone who wants to build a motor and buy a second hand job.
rb26's are depressingly expensive... if you do one thing u may as well do another and another and another and eventually you will be $20k out of pocket
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3201036
Amen to that - open your wallet, bend over and just take it like a pedophile in a jail shower!!!
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3201176
  • 2 months later...
Ok, as of 02/09/2007.........
Total Rebuild with forged pistons came to $6040.77
Break down of price
Engine reconditioning works: $1012.60, what was conducted is as follows.
-Degrease & hot tank long motor
-Engine block bore & hone
-Surface grind head
-Measure & linish crank shaft
-Dismantle, check tunnels, check conrods, crank & pistons
-Vacum test, dismantle & inspect cylinder head
-Bleed down hydraulic, fit valve stem seal
-Supply main bearings
-Supply conrod bearings
Misc. Parts.
-Set of JE Forged pistons rings inc. $1660
-Full gasket rebuild kit $358.84
Dismantle & Reassemble engine(Incl assembly of head) $799
4 Liters of running in engine oil $32.65
2.5 Liters of Diff oil $20.68
6 Platinum spark plugs $108
Engine timing belt $109
52 Hours labor to remove head and engine, reinstate $1960
engine after it was rebuilt, road test, bed in new rings
& service
I also replaced the gear box oil with the redline light weight $152.47
shock proof gear oil but that is not included in the total
rebuild figure
I have done a little over 2000km since the rebuild and am happy to report that the engine is running well & better than ever. I will be taking the car to AVO Turboworld in Melbourne in the middle of this month to have a final check over on a dyno, as well as a power run.
FYI, What actually happened was I noticed that when the engine was cold it would miss a little but when it warmed up it would come good. Except one day it didnt come good. So I had someone look at it and we found that cylinder 6 was compressing at about 49KPa(I think it was measured in kilo pascals), compared to the usual 160KPa(I think) from the remaining 5, so we pulled the head off and found that a big chunk of the piston was gone from piston 6. Later when pulled apart it was found that piston 5 had a hair line fracture. The engine was then rebuilt.
Most importantly, We arent sure why it happened or where the pieces of the piton went as on inspecting both turbos, they had suffered no damage.
Another point I will make is that this GTR is not very modified.....at all.
List of mods.
-Cat back titanium Fijutsubo Giken Exhaust and now JE oversized forged pistons-Only mechanical mods
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3323584
Yeah, standard turbo's went back on, but its still running standard boost and will stay that way. For now I'm enjoying the standard car, despite the slight increase in displacement. If it was feasable a set of standard pistons would have went in.
I also forgot to mention it has 2 Blitz blowoff valves, but there not really much of a mod these days.
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3323895
$6K for an RB26 rebuild with forged pistons..
got to be the lowest cost so far.
I'd be real worried about those turbo's now..
main problem with RB26 rebuilds though isn't it..
even if you were to put a set of hiflows on there, the cost to purchase and have them installed would be about $2K surely.
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3324500
I'm new at this but is there supposed to be something wrong with my turbos because they have been inspected and there is nothing wrong with them. Everything that needed to be replaced, was.
Tell me this, what was I going to say when selling them. "here's two Garret T28's of an R33 GTR for sale. In excellent condition with no shaft play, impeller blades all in good condition. Reason for selling: They were left over parts when I rebuilt the engine"
Can anyone please tell me why they need to be replaced. More importantly can anyone tell me why a stock version of one of the most alleged bulletproof and reliable motors built by Nissan managed to chew up piston 6
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3325083
detonation will kill any engine in time
hows your fuel pump after 10 years?
are your injectors flowing the same after 10 years?
changed your fuel filter recently?
what fuel were/are you putting in the thing?
it might have been on the edge when it left japan. whos knows what kinda life it had before
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3325384
standard turbos and valve guides still???
6k twice isnt going to end up looking cheap
If the turbos let go ( they have a habbit of letting go when removed and replaced) it will be a lot more that $6k
Looks like they used the old oil pump as well, next time they will have to change that tooand a lot of other stuff that will have ceramic dust through it.
https://www.sau.com.au/forums/topic/165362-rb26-rebuild/#findComment-3325708
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
