Anyone running this clutch? I cannot decide whether to go with the regular copper mic good for 640HP~ or the competition model 750HP~
What's the difference besides spring pressure? Anyone running this clutch? Is it still sprung like the regular coppermix? Hows the drivability?
are you making over 600hp? if not why even consider the comp version? especially as you are obviously concerned about drivability. then of course the more extreme clutch will be less 'driveable'.
over 750hp is big to me. and there are very vew big single packages making over 750hp that will be very streetable. it just seems to me your goals are conflicting.
anyway, if the carbon clutch you have now can handly 750+ then I'd just use that if it's in good health.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
