It'd be good to get record numbers in this one.. 35 so far
IN SO FAR
Marsss
Primordial
SECUR1TY
rukus
Blitz
Liz
JETR32
mike1987
burnsie
lingeringsoul
NXTIME
smasha
DRD-OOF
D_I_F
N1 R33 GTR
traman18
Dj Albert
Miss Turbo
Nismo_God
LOOF
SAM916
Taran
msnismo
B-Man
Joeyz
dontfeelcold
R32woohoo
Goldzilla
NSA11N
A31Deviat
damuscat
Merli... yes Merli
Trust33
E_Lu-SHuN
mlt15e
https://www.sau.com.au/forums/topic/165561-pizza/page/3/#findComment-3074080
  • Replies 227
Guest Joeyz
IT'S TIME FOR ANOTHER PIZZA CRUISE
register now and i'll start a list.... DO IT!
Friday May 18th
Meet: Chatswood Chase Car Park, Enter off Victoria Ave
Time: 9:00pm, Leave by 9:30pm
Destination: Palm Beach via Newport for Pizza.
Bring: CB's, a full tank of fuel and a good attitude.
Please dont do anything silly as we are on public roads.
Leave all that shit for the track
Pizza Place:
Lucky's Pep'e Pizza Bar
Shp2/ 303 Barrenjoey Rd Newport 2106 (02) 9979 1756
IN SO FAR
Marsss
Primordial
SECUR1TY
rukus
Blitz
Liz
JETR32
mike1987
burnsie
lingeringsoul
NXTIME
smasha
DRD-OOF
D_I_F
N1 R33 GTR
traman18
Dj Albert
Miss Turbo
Nismo_God
LOOF
SAM916
Please count me in. Cant wait!
https://www.sau.com.au/forums/topic/165561-pizza/page/3/#findComment-3083291
hey all, unfortunately i cant make it to this cruise!
however, a close family frined owns that pizza place, lucky bellerri, i think thats how u spell his last name!
he races in top doorslammer and my father builds drag cars!
and he has known me since i was born!
so hope you all have fun and drive safely!
cheers
-Garth-
https://www.sau.com.au/forums/topic/165561-pizza/page/3/#findComment-3092282
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
