also the figures different dynos give can be different.
your guys dyno could be reading high thats why alot of the guys who came to the vic sdu dyno day said thier cars were making 180-190 rwkw on this dyno then they come to our dyno day and only make 140-150.
if the sydney guys have a dyno day then you can compare.
also the air /fuel ratios are important.
ask yourmechanic if he has a reading.
meggala
Guest INASNT
any dyno operator can have your reading 500kw@wheels if they wanted to! i think when u got your car dynoed the first time they bull****ted u man!!
especially with stock comp and rich a/f ratios its impossible!
A guy with a r33 brought his dyno chart to the last melbourne dyno day, after he got his unichip done saying 194kw@wheels. but when he got it dynoed at the day he got 155kw@wheels!
:uh-huh:
Guest INASNT
Originally posted by turbomad
Yes my so called Unichip tune wasn't actually that in tune was it, however he will be fixing it this Sat, and if he can't for some reason then I'll get my money back. So I might be back to check up on his work.
what did the guy have to say when u showed him the graph from the SAU dyno day? did u ask him where your extra 40rwkw's had gone?
As I don't live in Melb I haven't shown him yet, he assured me that there's no way he would have left the A/F ratio at 10:1, so believe me come Sat I'll be sticking around watching his every move making sure he gets it right this time.
Guest INASNT
y dont u get a s-afc or power fc instead of the unichip?
S-AFC - Only intercepts & allows fuel map changes, it doesn't do timing as per the PFC or UC.
Power FC - Costly even @ $1200 for the Power FC add ~$400 for tuning, compare this to a Unichip $1100 fitted & tuned (this is what I paid). Without a doubt the PFC is the better option as reflected by the higher price.
Unichip - IF, & it's a big IF! The UC is correctly installed & tuned then it WILL provide repeatable rwkw gains. My Unichip was able to provide tuning for over 215rwkw (this kind of figure was repeatable on more than one dyno) I also managed the 1/4 time in my sig' with the UC running the show. The power curve & A/FR's were both very smooth & consistent.
BUT...... It took a good tuner who was familiar with both the UC & the RB25DET to get the results! The original installer did a very poor effort @ tuning it. Even the best ECU isn't much good if it's poorly tuned.
Once you start aiming for over 220rwkw the UC "may" have trouble overcoming the stock ECU's AFM over voltage timing retard. This is the exact reason I decided to get the LT12 Microtech, however it "may" be possible to make 220+rwkw with the UC & get a decent power curve, I just wasn’t interested in stuffing around trying to find out!
I think people shouldn't take their dyno reading to personally. A dyno is to tune the car. I've seen some cars sive different reading on the same dyno's.
My one had about 160kw at the rear at Hills and 180kw on 4 wheels on croydon's dyno. :confused:
Yes as Whatisname said it all comes down to cost, I paid $500 for the Unichip and $300 for the so called tune! Now with the SAFC I'd still have to add an ITC to get the same tuning features as the Unichip, which would throw it way over the $800 mark. Now that I've got the Unichip I'll try and get it right, if I can't then sure I'd consider an SAFC, time will tell.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
