i'm running the non dampered version ...
advantages:
ZERO clutch slip and grips great
can handle ALOT of power
disadvantage:
permanent muscle cramps in the left leg from pressing the pedal
engine stalls once in a while in heavy traffic when starting to move (needs >3000rpm to get rolling)
when shifting fast during races, every gear crunches
I would highly suggest this clutch to anyone, but personally i prefer the dampered discs because i drive my high powered RB on a regular basis...
advantages:
disadvantage:
so the non dampened version is less heavy on the left leg???, it seems the dampered version would be the way to go, how does it feel compared to the stock clutch(the twin plate orcs)???
not it is the same thing, im not sure what he is talking about all mine are feather light..... his sounds like it may be installed wrong..
the silent types has more parts which in drifting means more potential issues thats all.
Edited by URAS
  • 4 weeks later...
trent what's the weight of the flywheel on the 709?
I think that's the one I just had put into my car...
I will try find out, i just fitted the ORC pro carbon twin and i can say it is absolutey fkn awesome, the pedal effort is so light and it is very progressive (cat is a small chick)
  • 4 weeks later...
did u guys purchase this from greenline?
because when i go on the site, it doesn't say anything about it being a kit or including a flywheel.
How long did it take for this to land?
And what other parts "Nissan" parts did u need?
Twin Plate Clutch. Damper type. 700ps/110kgfm. Recommended for use with new Nissan flywheel bolts, release bearing and sleeve. Pull to push conversion kit included.
i ask because
Nissan genuine parts required for installation with Nissan BNR32(93.2~94.12), BCNR33 and ER34 models.
not sure what else I needed - mate put it on.
N1GTR - I don't like it and will change it off when I can afford to - mine is very hair trigger and I keep stalling it.
Anyone want to buy it off me? It's done less than 1000kms with off-idle take offs!
sounds like it was installed wrong, the carbon one in cats car and the twin in mine is sooo easy to drive, very slippable if needed (trailer loading etc) evan cat hs no issues with it..... it is very liveable as a daily.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
