I was just wondering - what actually generally gets done when a car gets serviced, for your average 10 000km service?
At what points do you need more work done?
Is there anybody who's taught themselves how to service their car (ie somebody who didn't previously know too much about cars mechanically) to save a bit of money
https://www.sau.com.au/forums/topic/166582-car-service-what-exactly-is-done/
best way to learn is to get someone to show you.
normal service is oil, oil filter, and air filter.
the machanic will tel you after he has done the service if anything else needs to be done.
yeh if you have a decent k&n filter etc no need for a air filter change, just oil, oil filter and i also change my spark plugs aswell, i do mine every 5000kms.
U change your spark plugs every 5000`s ?????? what for do u get problems with fouling they should last heap longer then that
Normal Copper plugs are meant to be changed every 20 thousands k's but for best performance there meant to be changed roughly every 7500k's thats why alot of people change copper plugs soo often
There was a whole topic about this somewhere on here
Mechanics will do more than just an oil+spark plug change - they look over the car for anything which is perished, loose, worn, broken, etc. They use their experience and qualifications (which i dont have), which is why i like to run my line past a mechanic every now and again to let them inspect it for something i cant see
Below is from the UAS website.
UAS General Service price is $220.00 (Skyline GTR $260.00)
and includes the following parts and labour:
Thorough check of your vehicle and report supplied, including:
Check all fluid levels
Check exhaust system
Check suspension system
* Check all drive belts
Check and adjust the idle and mixtures as required
Report on your brake level (% of worn brake pads given)
Check all tyre pressures
Check all lights
Washer jets adjusted if required
Washer bottle topped with cleaner fluid
Coolant condition checked
Engine oil "10w/40"and filter changed ( we use Motul 4100 synthetic type)
* OEM or Japanesee made oil filter - whichever is better
To clean and oil the performance air filter correctly (Extra $25)
Engine cleaned underneath
Clean and treat battery terminals, door hinges, bonnet and door latches
Road tes
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
