What changes must be done to a RB26dett engine to produce 500-600 hp.(oil pump,pistons.....)?The tubos will be replaced by hks gt 2535(prefered for small lug).The car will be driven every day. Is it better to buy a rb26det engine an modify it.(cheaper?)?
I readed somewhere that r34 gtr doesn't come with oil cooler.
In my country the average temp at summers is 40 C.I think a oil cooler is needed.Do you now a website that sells one?
i'm not too sure, and people, please correct me if i'm wrong, this is just my assumption.
you will need: full exhaust, air filters, turbos (have been recommended HKS GT2530), fuel pump, injectors, most probably camshafts, aftermarket ecu, boost controller, better front mount intercooler and oil cooler.
you might need: valve springs, retainers, oil sump (if planning track work), oil pump.
also, look at engine brace, because i have been told that over 500hp, the engine twists a lot and causes a lot of problem. certain parts of the chasis might need strengthening as well, someone might know better on this topic.
i think the standard internals should see 500hp, dunno how reliably though. buying an RB26DETT and modifying it might be cheaper in that you will not have to pull the engine out to modify it, but you still have to pull out the other engine at the end of the day, so don't think it's advisable, unless you've got heaps of money lying around.
and yes oil coolers are a must for these engines. driven hard in near winter conditions, temp around 15 deg c, my engine oil heats up heaps in about 10 mins. it's just one of the problems with GTRs.
try www.takakaira.com, they have all sorts of aftermarket stuff.
you may want to consider drivetrain weaknesses as well, before rushing out and just upping the power. i think the stopping power should be sufficient, but you might want to upgrade it as well. you can never stop fast enough.
Easy :P
Pod Filters
Turbo Back Exhaust
ECU (PowerFC)
600cc+ Injectors
Big Fuel Pump
Bigger Front Mount (600x300x100-ish)
Your choice of turbos:
HKS GT2510 - 500hp
Nismo N1 Turbos - 500hp
HKS GT2530 - 550-600hp
HKS GT2540 - 600-650hp
Those are rough figures (so don't all reply saying GT2510s can make 510hp), just so you get a feel for the comparative sizing of the turbos. Any of them will get you past 500hp fairly easily... Depends how much more than 500hp you want, and how much bottom end response you're willing to give up for the extra top end power.
Recommended ancillary upgrades to handle the power:
Twin plate clutch
Oil cooler
Brake upgrade (pads, braided lines, good fluid)
So i will need
1. Full exhaust
2. Ecu (power fc seems to be the favorite,with the boost
controler)
3. 600 cc/min Injectors
4. Fuel pump(?ltr/min)
5. Intercooler(600x300x100)
6. Oil cooler
7. Twin plate clutch
8. Brake Upgrade(size ?)
9. Engine braces
10. Race catalyst
11. Air filters
I would like to know the best brand for every component in the above list aswell as prices.Anythink else i must add to the list?
Is hks gt 2530 turbos a better matche for the rb26dett than 2535?(are 2535 more lagy?). I readed that the standart gearbox can take up to 600 hp.Is this true?The same goes for the engine internals? Do i realy need a new camshaft for the hp i aim?If i do, what duracion (degree) must i get?With allmost double power than standart shout i change the size of the whells?If so what size you recoment.
Guest nismo_trip
It would probably be a good idea to get some camshafts and wheels to get the full potential out of your new turbos, maybe some 264 degrees in and out, as for your engine holding together yeah it should, maybe you might want to buy a metal head gasket to lower compression if you want to be cautious
to produce(353rwkw)...all i did was got the standard t28 turbos hiflowed,780cc inj,motec,upgrade fuel pump,boost,intercool,single 75mm throttle body...but mind you i had the rb26dett fitted into my vl calais which ran a 10.8 @ 127 on 20 psi...
www.axg.net/gg/ct/movies/omy11s.mpeg
Originally posted by The Dog
How long will the engine hold tougether?As i said the car will be driven exery day.
in my r34,i have
trust t517z turbos
power fc
660cc injectors
bosch 044 fuel pump
trust oil cooler
hks hiper exhaust
trust cam gears
im around 600hp.
dont bother with headgaskets or headbolts or even camshafts.
im even running standard cooler.
if ur chasing 350kw+at the wheels,u may need intercooler,but if ur aim is 300kw+ approx ,above is all thats required.
there is a heap more u can do,but unless your spending time at the track,theres no real point.
u can throw an extra $10k at it,may be more durable,wont go any faster.
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
