Has anyone used Shell 100 octane 'race fuel' as they call it? Just want to hear some of your feedback about it and how it is.
It contains 5% ethanol is this good or bad? I used it and the car was running pretty good but i dont know if there was a difference between normal 98 octane optimax or ultimate.. (and for you mobil people synergy 8000)
https://www.sau.com.au/forums/topic/167106-shell-100-octane-petrol/
You mean V-Power Racing? It's the only fuel I use in my R33. It seems to run the best with it.
EDIT: There is a difference between V-Power & V-Power Racing. The former being 98 RON and the latter 100 RON.
V-Power racing is not available at all Shell stations.
Edited by HotPlates
I used to use it in my car, it caused my check engine light to come on a few times and i got 40 less kms out of a full tank.
That was when it first came out, it might be different now. BP ultimate rocks (not trying to start a fuel war thread lol)
Without going into it too much as we've discussed this many times over... IMO, I think Shell's V-Power is the absolute best... I get more milage, less ping and more bursts of power....
the shell v-power raceing (100 octane) was good im my 31 even being lightly moded still noticed a diffrence.
its good use it just rember it cost more.
V-Power Racing is the best fuel i have used....
do not worry about the ethanol, for any corrosion to take effect, it wil need at least 5-8years. by then your have to rebuild your engine any way....
i use it, brings my knock down to under 10 in hot days...high octane fuel FTW
the only problem is it is not available at too many places
and the nozzle of the pump sucks!
pisses me off how wa gets none of this shit!
by shit i mean good shit!
ha ha ha. i feel ya frustration and fair enough too. geographical locations, plays a big part of marketing unfortunately.
having said that, unless you have very well-tuned skyline with a lot of performance modifications, with V-power fuel you still wouldn't feel such a difference unless you really hammer it.
this is my personal experience, I've tried Optimax 98, Ultimate (with also 98% octaine), V-Power and a few more too; but i have to say, if you're just cruising a long, then anything with 98% octane would do the job and you would feel the extra juice, however, with V-power i noticed that the difference isn't too substantial unless you really push the car to its potential. one time my friend and i took our cars to caulder park, did some quarter-mile times and because i was literally 'flooring' it, at the peak i did feel a slight boost in power due to the V-power fuel. not bad i must say. but then again it does cost much more than usual fuel though.
so yeah, that's just my thoughts on it. i'm sure others will have their opinions too.
cheers,
But we import car drivers have to use 98+ octane anyway. So you can't compare to 92-95 when we can't use it anyway.
Also, V-Power Racing is just as expensive (or a little more) than the Mobil & BP stuff. Eitherway, the BP & Mobil 98 made my car start to stall. V-Power, not one problem.
fair point. :laughing-smiley-014:
cheers,
octane is not measured in percentage is a rating number. also to get the full effect of a higher octane fuel u should get the timing adjusted accordingly usually advanced a degree or so. also with the ethanol content i wouldn't worry so much about the corrosion but more so the fact that ethanol leans out your a/f's only slightly but if an engine is tuned on the 'edge' then this could kill it.
I have done some work for a EFI manufactor in the past and they did tests using ethanol. Its not to good. It is corrosive!
They had stuffed injectors and all sorts. I got told to stay a way from it.
It is made using sugar, which if enough gets in your fuel tank can destroy a motor. One of the old revenge tricks was adding sugar to someones tank.
I don't usually go in for all the "this fuel is better than that one" BS, but I moved not long ago and now the closest servo to me is a Shell. I've gone through 2 tanks of the V-Power (98 octane) and I've noticed that my pinging and timing are way better then when I ran it exclusively on BP Ultimate
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
