very keen to see what you think of the FET ones. they are black right? with a little red bit on the top? i've seen a few saurus cars in japan using them.
all red, but mine are quite old the newer ones may be differrent. I will check.
They are all red
There is another company making similar coils called Okaka Projects, not sure what colour they use.
hmm, that could be them. i am running the splitfires now (and they have been fine to this point), but I can't help but feel there is a better option. I notice some very hardcore cars built by saurus running what I think are the FET ones, and I noticed when I was at veilside their R32 GTR drag car was running standard coils... I was so shocked I even asked Hiranao to make sure. as at the time it went against my belief that standard = crap. I now seem to lean towards: worn out standard = crap, but brand new nissan coils = the best (but cost is way too much).
http://cgi.ebay.com.au/FET-DIRECT-IGNITION...8QQcmdZViewItem
found these for sale on ebay ^^^^ they are the same as the ones i have.
Edited by URAS
I always worried about editing this feature in the PFC because I believe Datalogit have their description incorrect. How can coil dwell be dependant upon rpm? Secondary coil voltage is dependant upon input power so with a fixed impeadance only voltage and dwell will affect the final spark engergy. Most of the jap stuff I have seen - including tuning of factory ECU's, coil dwell is allways based upon amount dwell vs battery voltage not rpm unless of course its duty clyle based - but then the numbers dont make sense.
Has anybody had time to scope the dwell after editing this table? And yes there is a point that more dwell will result in less secondary coil voltage.
Maybe the thinking behind this is that if you give the coil enought dwell to produce maximum spark energy all the time, then they will overheat, so i guess you could give it a bit more dwell around peak BMEP/torque, to give it the added spark energy without the fear of cooking the coils, as they aren't getting that dwell much of the time? I remember reading that splitfires like a bit more dwell than standard, so i believe it is possible that they may have a different gauge wiring, combined with a different winding ratio between the primary and secondary circuits, food for thought..., please feel free to diagree
I hear what your saying but spark energy is "usually" a function of dwell vs batery voltage not dwell vs rpm - as it is within the datalogit software. Dont get me wrong this table may affect dwell but it may just be worded incorrectly and the scaling from hexidecimal to actual engineering numbers may be wrong. Its one of those things I would test if I only had a free second at work!!!
why are these settings sweet?
what are the benefits of these settings?
Are these going to be best for all cars? if not which ones?
as there isnt much point for posting it if there isnt anything for everyone on the forums besides tuners
Ther was a thread on here a while ago about increasing the dwell on PFC to 1.7ms to suit the splitfires, is it only from the datalogit, or can it be done from the h/c(its been ages since i used one.)I would have thought dwell vs batt voltage would be a no brainer, batt voltage down a little, give it a bit more dwell. If this works as rob says and isnt just a bad translation, i dont see why everyone couldnt tailor their dwell to suit their application, could even set the PFC up to run external bosch coils if the range is big enough(how high can it go?)
Edited by Adriano
There is almost always two settings;
IGNITION VOLTAGE DWELL COMPENSATION (amount of time added to base ignition dwell as a function of ignition voltage)
IGNITION DWELL PERIOD ((length of time the ignition coil dwells as a function of rpm) sometimes this is a percentage of duty, like remaps for example)
My thinking is that there is a scaler of "base dwell time" that is not accessable via datalogit or the hand controller. Then there is a mutiplier "IGN vs BatV" which should read "Ignition Dwell mutiplier vs BatV". Then the "IGN dwell vs RPM" is another mutilpier based on RPM.
Also it cant be duty cycle based as all nissan's use dumb ignitors.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
