logging boost level has little to do with a controller
e.g aftermarket computer usually can do this, best get one with a map sensor :) this way you can map rpm verse boost and see the whole thing (vs a/f ratio etc)
you could get an ebc with a max boost peak recall, or even just a defi gauge (or similar) that has a peak boost recall. but it wont tell you when it happened or for how long
Edited by InterCooL
Yeah I have standard ECU and a mechanical boost guage, neither of which are any good for me....unless of course I can use that map sensor that the standard boost guage uses (on the firewall).....anyone know what it outputs?
I don't just need peak recall, I need regular output to a proper logger (eg 10x a second). Required by the regs of our race category.
yeah duncan, for the logging you will need a map sensor that can input to your logger. the factory map sensor should do the job. if you want another map sensor I have one here, you can have it for free (I still owe you for some sun visors from eons ago). I bought it when I though my map sensor was dead (turns out I was wrong). I use a defi gauge which doesn't just have peak, it records. can only record 5 minutes at a time, but it's cool cause I can do a few laps with it recording, then pull into the pits and play it back and watch boost, oil pressure, oil temp and fuel pressure in real time.
as for a good boost controller the HKS EVC IV and the Blitz SBC ID III are both supposed to be very good. I use a Greddy Profec B II and it holds my boost flat as a tack, so for me it's a very good controller. and they are cheap.
yeah I wouldn't be looking to run much boost either, 12psi when racing and 16-18ish when not running under 3e regs.
speaking of the standard map sensor, it doesn't seem to go to the ECU? is it only used by the stock boost guage?
yep, it's cluster only. i've pissed mine off since running the defi gauges and never looked back :)
if you want this map sensor dunc, just give me a yell and I'll pop it in the mail for you to play with.
nah its cool I've got mine still installed.
Can't find any info on the voltage output of the Map sensor or its range in the manual, I guess I will need to calibrate the output against the boost guage manually. Hope it doesn't max out at 14psi or somethign.
I had a quick look at these, the "data logging" seems to be the same as the defi guages, ie the guage itself can play back what happened.
I need an output of boost level that I can run into my data logger insead
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
