No you don't.
I just installed a Tomei pump which is nearly identical.
It's enough to push some serious power without a regulator, up to 300rwkws ?? i believe
If you wanna save a bit of cash,
1) don't get the regulator
2) get the Tomei kit, i don't know but, they look the same and are rated the same and i wouln't be suprised if they ARE the same with a different branding. Tomei is a good brand and i think $50 cheaper.
Yes, reasonably quiet, i can here it but only if the radio is off and standing still.
Check the DIY threads, there's one there with heaps of pics and some of mine showing the unit.
It is a DIRECT swap, slide one out, unclip 1 clip that goes on the new bracket and slide the newie back in.
Easy.
No you don't.
i just fitted the tomei pump to cats car and it pulled 330rwkw no dramas, i love the check valve setup so it primes instantly
Edited by URAS
With the nismo reg do you just install and go or do you have to set it up to specific pressure you are after
About to install pump and reg + new injectors but unsure if I can chuck it all together myself set correct settings in pfc and go or do I need to get it all installed by tuner. Plan to get it on the dyno again anyway but would rather install parts and just pay for tune rather than time to install as well as tune
If that makes sence
If that makes sence
NO. you need to set your fuel pressure with a fuel pressure gauge. do not just bolt on an adjustable reg and hope for the best. could be a recipe for disaster. :P
yes! That is the only reason I bought a sard reg over the nismo one. I wanted to have a fuel pressure gauge tucked away with a warning light. a fuel pump has died on me once before, and I'm paranoid about it now (and fuel surge too). the beauty of my sard reg is the defi sensor just plugs into the side, and when setting it up I can hit a switch on the defi controller which eliminates boost/vacum from the reading so I can accurately see the base pressure withiout having to unplug the vac line etc. :banana:
but yes, you can t one in, just a bit of mucking around.
The R34 should be no different to the R33, if so it will be so marginal you won't care.
Just read the R33 thread.
The pics speak for themselves.
Price on Tomei pump (Someone asked) was $340 deilvered from nengun and i suspect it's now cheaper as the dollar has gone higher.
Good luck peeps.
...the beauty of my sard reg is the defi sensor just plugs into the side, and when setting it up I can hit a switch on the defi controller which eliminates boost/vacuum from the reading so I can accurately see the base pressure without having to unplug the vac line etc. :pwned:
Nice choice of hardware :D
Interested in which button you press on the controller and its effect? Shouldn't turning key to "accessory's" give you a base pressure
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
