Hey guys, where could i find a low jack and some decents stands for when i put my car up on stands. and what is a good price to look at?? also where are the jacking points on the car (front and back) also where can i put the stands so i can have all four wheels off the ground.
thanks
https://www.sau.com.au/forums/topic/167357-low-jack-and-stands/
thanks
pretty sure you can pick these up from supercheap/repco/malz/any other auto place. point for jacking see infront of your rear wheels on the chassis there are points and behind the front wheels.
The spots behind the front wheels of my car are very weak, I have damaged the underside of my car by trying to jack the car up here :P. I now use a rectangular piece of MDF to place between the jack and my car to avoid further damage to my baby....
ive found the best bet is a couple of scafold planks and afew bricks to make a ramp forward onto then jackup from the diff and place stands under subframe
the stands are homemade using heavy materials and qual welder mates and the jack is just a supercheap trolley jack
low jacks are bulk expensive scafold planks are free aquired from site
Similar to above, but using a half brick and then a full brick under one side. Then the trolley jack slides in nicely to the crossmember.
Use the beefiest stands you can though, if you are going under the car, make damn sure it can't move on you..
i will need a good quilty jack. like one the is long and low. i will be using it a lot and i reckon it will make work on my car a whole lot more eaiser cause i will be under it. and it might come in some time that i will have my car on stands overnight. i am willing to spend up to 500 on the jack. so like anywhere here sell em or do i buy of the net??
SnapOn make an awsome one under the Blue Point name is without a toubt one of the lowest trolleys jacks i have ever seen.
When dropped down the front of the jack is about 40mm high but they still raise up to about 500mm if i could afford it i would buy one straight out.
I made some little MDF wood ramps to get a lil extra clearance when jackin my car. Very simple just 3 piece of 15mm MBF all cut at diffrent lenghts then glued on top of each other. Then stuck a piece of rubber mat on the bottom to stop them slipping on the concrete as i drive up onto them. very effective and i have been using the same ones for about 5 years now.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
