Hi All,
I am hoping everyone had a grand old time last nite, I know I sure did even though I had to work. I hope that the pizza was adequate and delicious.
Tell me what u guy's think if we meet up for pizza and a cruiz every 2 months or so??? Just an idea for something regular for us to catch up.
Take care guy's untill next time!
Mark
:P
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/
Pizza was Yummmo.. :P Thanx Mark!!
Nice to have met you guys..
Milk...... you crack me up girl.. :)
And Pred.. you remind me of the guy in F&Furious big time.. lol
Cant wait for Sunday now... still scaredddddddd.. lol
TTFN
Kyles
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/#findComment-346850
lol ..
Ask any racer, any real racer. It doesn't matter if you win by an inch or a mile; winning's winning.
hehe
nice car too kyles.. luv the rims! i should have mine back tonight.. and u know what they say about red (well burgandy) cars.. we should have the others covered ezy :P
yup, sunday should be good, hopefully everybody comes who said they would - its an early start! but should be worth every minute of it.
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/#findComment-346932
thats great guy's I also had a great time. I can't wait untill we do this again!!! Maybe we can go somewhere else for food so it can be fair for those who traveled for ages to come down. I love ur car BigPsi!!!!!
32 ENVY there will be many other times for you to come, next time no excuse ehh!!!
:P
take it easy guy's
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/#findComment-347260
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
