drifted my brothers 180sx today, 185rwkw 15 then bleeding off to 12psi. 20 mins intervouls and filled up a whole drift catch can (i think 1L) which is a f**kload too much, so kept pouring back into the engine as it was still good.
Looks like the engine will be stripped, new block, re ringed pistons and re assembled propperly
no no. its a clearance issue. my sujestion is to have a look at the bores. when you did the rings did you chamfer the edges whewre you filed them?
if its ok. stick in some woolworths oil and give it a hard time for a few hundred kays.
From what I have read of this thread, in my opinion it's simply a matter of too much oil getting to the cylinder head. It's not blowing it by, it's simply filling up the cam covers at high rpm. ONE OIL FEED IS ENOUGH, that's why RB26's have one blocked off STANDARD.
So get on with it, pull the head off and block off one of the oil feeds. Check the bore while you are at it to satisfy the "blow by" callers.
Why is it doing it on this rebuild? Because you are using higher rpm and/or more frequently and/or for longer periods. If you aren't, then you wasted your money on forged pistons. It only takes a little bit to tip it over return to sump flow rate.
:D cheers :D
sky30, we left it at one stage and overfilled and spat it all over the joint.
I didnt build the motor, MSC Performance built it and duggans rooted the machining, thats all it is, a shit build with a shit machine and an overpriced job.
i had the same kind of problem. i used to lose around 2L of oil every few days, but im running nowhere near that kind of power.
the problem was the oil drain pipe being blocked by the pcv - the build up of pressure in the crank wasnt letting the oil return flow freely.
same principle COULD apply here.
i noticed that you said the oil return for the head was routed to the oil return for the turbo. is it possible that the return you plumbed into the turbo drain pipe blocking the oil drain for the turbo? its possible that the oil is backing up all the way to the turbo then being forced out of the oil seal ring.
Its spitting litters of oil into a catch can not burning or leaking it. The problem is not apparent on the dyno but perhaps not enough sustained high rpm loading is seen during a dyno ramp to fill the head. Which brings us back to the restrictor sizing as had been mention by sydney kid.
i didnt see where he said it was emptying into a catch can. my bad.
yeah but.... what has changed compared to the old motor in regard to revs/boost etc etc. from the sound of it its the same motor just with forgies and thats it.
he was running 15psi, now hes running 18. i know its a long shot, but could that have anything to do with it?
the head return may be blocked because of the combined oil drain. i've proven to be useless in this matter so now im just throwing up ideas.
regardless of that. it wasnt doing it before. 3 pound is f**k all more boost. and its not the oil return. the factory isnt idiots.
i agree theres oil up top. but whats making it "blow out"? corner g-forces i think not.
also. what turbo is on it????? this may sound strange but with my gtr i thought i stuffed the engine when it took aprox 5-10 mins of full boost driving to cover my engine bay and guards in oil after filling up the catchtank.(they were out of a blown motor with spun bearings)
the problem? worn out turbo thrust bearings. it seems boost was leaking past the bearings in the turbo,presurising the crankcase and blowing it out the breathers.
new turbo=fixed.
worth a look at. if you have a smoke tester or make up a adapter to presurise the inlet tract befor the throttle body to see if t is thr turbo leaking.
if not. do a leakdown test.
also a long shot. has any part of the sump changed?? of the windage trays not been installed??
SK- Okay head is off- bores look very good. Blocking one oil feed off. I believe the CPs will have more blow by than std and that may be enough to tip it over the edge. The old build would spit a little bit out but only when it fluttered the rings on limiter for extended periods of time. Thanks for your input.
Running in was about 20 seconds of getting oil pressure followed by nothing but full throttle (only 6psi or so) and no big decels for the first 150km. Then it had 600km of hard driving with no extended cruise or idling times. I used the cheapest oil i could find. Then it went back to the dyno for the 18psi tune.
T04GTR- Ring gaps were as per CP setup info- about .026"-.028" Can't remember which ring was larger gap. Yes I chamfered all the rings. The only vertical lines in the bore are from the piston skirt and they are very minimal.
Edited by lukevl
this is such an annoying problem!! it used to piss me off badly.. mine did it because every piston had cracked rings and the boost was going into the crank case..
Once it blew by that much that a whole litre of oil squirted onto the red hot exaust manifold... No fire.. just a SHITLOAD of smoke. never have you seen a cloud of smoke that big :P
I even pulled my head off and blocked off one hole and it made a big difference but still squirted because of the rooted engine.
Ever since i got my engine rebuilt with ACL forgies i have not had any issues at all... not have i even checked it.. i have my catch can plumbed back into the intake because i like to keep it legal.
Might check it for blow by on my next dyno session...
i think the fact it fills the can on high boost, but not on low boost tells me it's rings/bores. and you said even when thrashing on low boost it doesn't fill the can (so it's not the high revs pumping all that oil that's doing it), but when you are running on high boost you are filling the can. so to me the diagnosis seems clear. but there is only one way to find out for sure. :blink:
Beer Baron- not really. Going from low to high boost gives it about 12psi and over 120rwkw or so. That is going to make a lot more positive crank case pressure. The motor will always make positive crankcase pressure due to the cylinder pressure getting past the rings. Its probably just very close to spitting oil out on low boost.
EDIT- Its fixed. No more oil dramas. Goes like a cut snake and doesn't regurgitate oil. I love it. 'SK- I am sure you are very shocked by this. Thanks
Edited by lukevl
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
