OH, YOU HAVE BYPASSED THE FUEL PUMP CONTROLER HAVENT YOU? (if in dought just earth the earth of the pump and it will get full voltage all the time. my 32 had a simalar problem. turns out it was the controler not the pump lol.
so just eath the negative pump wire and see how you go. and definatly get the shop to put a fuel pressure guage on it to see if its doing what i think its doing.
t04gtr, like you, I don't like the boschs for the same reasons. People are always like buy the bosch, buy the bosch. There is absolutely no advantage buying a bosch over others (except a slight price difference, whcih is diminished when you have to buy 2 040s in 2 months)
unlike others who have found that they dimish when they get hot, we've replaced a few that have actually broken.
Edited by MANWHORE
I also replaced the stock pump with the bosch in tank 040 which I bought from Speed Tech in Mitcham.
When I bought it they removed the one way valve which they said was not needed.
Every Fuel pressure gauge I have put on there (4) has beaten itself to death in a short time with excessive fluctuation.
I put the one way valve back in the line hoping to stabilise the reading but it has not helped.
I also have a Malpassi silver top on there as well.
Not sure which way to go from here.....
no idea, the problem is gone, not sure what was happening there. still grinds n shit, i just hope its not struggling and thats what the stuttering is here and there. time for a tune.
Mappassi's are well known to pulsate the pressure a little.. or a lot :domokun: >> http://www.skylinesaustralia.com/forums/in...998&hl=SARD
Bosch pumps do get groany when the fuel heats up. When mine wasn't receiving full volts it was so bad the floor pan would vibrate and could be heard/felt over the radio.
Rofl - nice. Hey are you using the 040 or 044. As with TO4GTR's comment below.....
the o44 is a gem. no dramas regardless of mounting style
Are yall saying its just the 040 that gets noisy when hot? As I thought both models were quiet similar bar, mesh and one way valve?
I thought the noise was a direct result of cavitation when the fuel gets hot. I figured the bubbles found it easier to make their way to the intake from the return, or maybe just the extreme vacuum and turbulence over the rough threaded fitting caused it.
If the 044 doesn’t get as noisy as the 040, read: doesn’t cavitate as much, there must be a reason. Are more people fitting the stock sock to 044’s?
*ponders*
I had an 040 that failed on me. It just got really noisy sometimes then it became all the time followed by fuel cut. I promptly changed it with a Denso pump (also made by Bosch). The reason I was given for the failure was that I had a lot of crap in the bottom of the tank. I got the tank flushed and have not had a problem since. The Denso is also a lot quieter.
I have also heard that the filter in the 040 is not very good at filtering out rubbish compared with the sock design of most other pumps. From my experience it is well worth spending extra on a proper Nismo, Tomei or Denso pump and save yourself the potential hassles.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
