HELLO i own a R34 coupe 2.5ltr neo, tiptronic auto ewww, has a K&N air filter, removed the cat, new iridium sparkplugs, well serviced only done 100K... the problem is i fill it up at $80-$90 right to the top about 60ltrs i think and it only goes as far as 400k-430k depending on how i drive it!!! ive had it hooked up on the scanner tool and all the sensors are fine. thinking of some performance chip in future aswell but not if it going to drain more fuel and yes i will be getting and exhaust extractor and putting a manual in soon .. the point is that i should get 100km to 9.5ltr-10.5ltrs of gas.. any ideas if there could be something else wrong...cheers
https://www.sau.com.au/forums/topic/167754-gas-guzzler/
hey mate i have a r32 gts-t and i do about the same from a full tank. i always refil when i have 1 quater of a tank left and i have usually done about 330kms by then.
so yeh i think thats about normal.
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3103326
i also fill up on 1/4mark and get about 300km~ :whistling:
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3103389
Ive got an R32 RB25DE
i get a little less then you normally..
BTW if you do a search theres 11tybillion threads on similar topics
yes there is heaps of threads on this but none to do with later models, i have heard about the vct on the neo heads can sometimes put the timing out
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3103483
just thinking out loud here.
seems like the NAs no longer get the fuel efficiency they used to. wonder why?
back when i first got my car, i'd get 500km+ easily... 600 when i took it for highway, easy drives.
is it the fuel or the age of these cars? two of my mate's gtsts (one is stockish, runs high 13s. one has 250+rwkw, runs mid 12s) both get something like 400-450km/tank driving off boost.
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3104491
Funny, mine did the opposite. When i got it it was getting about 330-40kms to a tank (9km/l), and now i'm getting around 600kms. The only thing i changed was running V-Power for a while while it was cheap, and then kept running vortex or Unleaded 95 from shell.
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3104660
i got about 480k's out of my last tank of v power racing... the fuel light was on and off for like 3 days... never been so scared in my life! :blink:
i normally aim for 400, my needle is pretty low about then, but theres still about 15litres left in there...
im running a GTS-T though, and often run it boosted...
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3105541
i got about 480k's out of my last tank of v power racing... the fuel light was on and off for like 3 days... never been so scared in my life! :huh:
woah thats incredibly depressing...
i get around 500k's to a tank average driving with my beast :blink:
your economy is not normal people, maybe professionally clean injectors, new 02, clean afm, make sure the engines in good service and tune (plugs, timing) check compression... no exhaust leaks? smash it on the dyno, check out a/f?
invest in a safc and lean out your mixes :P
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3105606
I'm getting about 330 till the fuel lights come on.
I think I average about 100km for every line. 3/4 tank = done 100km.. roughly..
would LOVE to learn how make my car go further every tank..
cheers
Exactly the same.
I seem to get close to 100km per line, then it just drops bad when it goes past half way haha.
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3105994
R33GTST - I average 500kms per 45-50L - 70%-80% is freeway driving though .....
yeah i do about 5% freeway/motorway driving... depends where i go on the weekend... even then, im probably in a rush and still boosting it :P
my fuel economy is about right... probably a little better then normal... im not very conservative with fuel, yet it goes pretty far :D
https://www.sau.com.au/forums/topic/167754-gas-guzzler/#findComment-3118186
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
