  • Replies 82
Just moved down to Sydney last week. Would be good to meet some other enthusiasts down here. I'll prob be the only one that doesn't know anyone there, but count me in.
I tell you your roads down here are ... !? Feel every bit of it too.
Hopefully some of u can give me some pointers on where i can find some nice roads (Equivalent to Sunshine Coast Hinterland, for those who have been to qld).
Welcome to SAU :worship:
Can definatly show you some good roads soon ....I feel a cruise coming on :banana:
See you tomorrow night :happy: Also I hope you enter you car in Show and Shine!!!!!!!
nvm that! I'm in :D
Hi5!!! :banana:
chatswood :( ill be spending more on fuel then ill be spending on the dinner. not sure if i can make it out that far tomorrow night.
:yes: Thats ok Nick, Wish you came to last month's was at Mean Fiddler, but I might bring a dinner to you in the coming months, well at least out west somehere :3some: see what happens
I'm in Jess, love the past dinners that you've put on in the past so I cant miss this one. :worship:
Look forward to catchin up with the regulars & new peeps 2moz, I have to admit the food at the Northern is top shelf & complimented with a beer or two is da bomb ( great atmosphere ). :banana::3some:
C u all soon :yes: .
HHmmmm another one who claims the Great Northern as a local watering hole.... I have actually met another Ian up there too... will find out next Thurs :D
Thats right..........being 2K's down Mowbray begs the difficult decision some nights. Do I drive or spend the buck 70 on bus fare to get up there.
The Busdriver doesnt stop sometimes so........ :D
I will be up there with friends as usual so prob be mixin between the 2 groups. :P
if someone can bring a members form, i can only stop in for just a bit. :P
I can bring one for you, no worries, But this is not a members only event
Everyone is welcome :D
Thats a shame you cant stay for long
another great event organised by jess, thanks it was good to see everyone yet again....
watching ando clean up the pokies and pool was pretty cool.... pitty he still drives a taxi!
hope loose pants were worn after i left!!
I am sooo hungover right now......
back to bed for me :D
great to see everyone again and soory if I got waaaay to smashed!
Ando - how was the long walk home? :(
Nick - your mrs is lovely ;) and get her to come to DECA!
I need a panadol!
back to bed for me :(
Ando - how was the long walk home? :cheers:
Nick - your mrs is lovely :cheers: and get her to come to DECA!
I need a panadol!
Haha chubbs was smashhhhhed!
I need more panadol!
All,
Something urgent has come up and I won't be able make tonights gathering. Have a good night n catchas another time.
I was wondering where you had got too...Hope to meet you soon :cheers:
Thanks everyone for coming was a great dinner and I had fun as usual :(
Was nice to catch up :cheers:
We will have to do it again soon.......
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
