  • Replies 131
Now we just need to get Carlos and we have the old skool team northside dinner crew back together
You rang...
Geoff told me about this event, and I am happy to report that I am in! I shall dust off the skyline and come along.
Look forward to seeing the crew, I have not seen you guys in such a long time!!
you're not updating the list well nick!!! a few people have said yes, that aren't up there as attending :nyaanyaa:
Will have to confirm for myself closer to the date!! depends on work! its getting hellla buusssyy :pwned:
Now now, dont be mean Mona im busy as at the moment.
Dont tell me there is a chance you might actually make an appearance! ;)
Dont tell me there is a chance you might actually make an appearance! :pwned:
lol!!! yeah maybe! i don't eat beef though! so will have to check the menu to see if there is any tastey chicken on zee menu! :nyaanyaa:
lol!!! yeah maybe! i don't eat beef though! so will have to check the menu to see if there is any tastey chicken on zee menu! :whistling:
Moanie,
They have the best 1/2 or whole chickens in the world.
They also do pork ribs and seafood
Saw you driving what I presume is your new toy yesterday Andrew. I don't think you should cry too hard, your choice of car is commendable.
Guest Joeyz
If i may ask and i might be asking a bit much here.
Question to all Team North Side guy's an gal's. I'v only been with SAU for about 3months and still learning alot about it but was wanting to know how did you come up with this name and what is it all about. How long or when did this start? :)
Question to all Team North Side guy's an gal's. I'v only been with SAU for about 3months and still learning alot about it but was wanting to know how did you come up with this name and what is it all about. How long or when did this start? :D
Its a long story Joe, and started many years ago.
If your lucky we might divulge the origins of TNS to you on the night
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
